Crankshaft Damper Replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-07-2020, 08:03 AM Thread Starter
Jason Pittenger's Avatar
Does the crankcase have to be split to replace the dampers?
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #2 of 3 (permalink) Old 03-07-2020, 08:08 AM Thread Starter
Sorry guys, I just found the sticky on this. The forum isn't letting me delete this post.
post #3 of 3 (permalink) Old 03-07-2020, 08:08 AM
the dampers that always fail over time live in the left side of the engine.
no case split, but will require removing left cover (where the stator and flywheel live) to change. this requires at a minimum of tilting the engine to get the cover to clear the frame, or removal of engine which gives lots of room!
michiganteddybear is offline
