Ah s%$#. Broken bolt. - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 11 (permalink) Old 03-08-2020, 12:47 PM
Originally Posted by rerb View Post
Found it. That will be my plan B if what I just did doesn't work. I drilled out the old bolt with (I think) a 5/32 bit, and then tapped it with an 8-32 NC tap. I'm just hoping the smaller size will still allow enough torque to create an airtight seal. Thanks everyone for your help!
It doesn't have to be real tight. I was able to take the old gaskets off the reed boxes with a razor blade and use those on the coasters. A touch of sealer might help. Would be better with the old bolt out, but it should work.
Tags
ear shave , reed valve , snapped bolt
