Where to buy flywheel removal bolt? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-28-2020, 08:32 PM Thread Starter
Does anyone have any recommendations on where to buy the 18mm x 1.5mm bolt needed to remove the flywheel online? Or any big box stores that stock them? I'm looking on replacing my dampers while I have the motor torn apart.
jakob_rothfuss is offline
post #2 of 7 (permalink) Old 01-28-2020, 09:01 PM
There's a bolt on the engine that works.... Just a bolt is all you need.
Quote below is from this thread: https://www.vn750.com/forum/70-proje...ad-gasket.html
Originally posted here: https://www.vn750.com/forum/31-engin...ok-here-2.html
alternative to the flywheel puller tool (the bolt), is a bolt for the upper chain tensioner.. just above the acct (or mcct if converted), on outside of the head. I (and others) have used it with success. its the right size thread,, just a hair short. you can use a small socket inside it (its hollow) to give it that little extra length (it dont need much). pops right off using it.
post #3 of 7 (permalink) Old 01-28-2020, 09:26 PM Thread Starter
Wow! Cool, thanks. Appreciate it!
post #4 of 7 (permalink) Old 01-29-2020, 09:43 AM
Wink
You're welcome, that's a great tip from michiganteddybear!
post #5 of 7 (permalink) Old 01-30-2020, 04:34 PM
macdj250's Avatar
Be careful and take it slow. I stripped out my first bolt attempting this. It actually bent and mishaped the bolt when it was funneled into the channel within the socket.
The second attempt I placed another smaller socket inside the threads of the bolt. (I don’t remember what size). But it fit loosely enough to pull back out easily. But still hold the integrity of the bolt as it went through.
1995 Vulcan 88 (1500)-complete rebuild-oem
1981 GS850GL-complete rebuild-oem
1988 Vn 750-current project-bobber
1985 Madura 750-next in line project.
rebuilt 5 other bikes, but don't own them anymore
macdj250 is offline
post #6 of 7 (permalink) Old 03-29-2020, 12:29 PM
i want to know too
Isaac1022 is offline
post #7 of 7 (permalink) Old 03-29-2020, 12:31 PM Thread Starter
Reference Spockster's above post about using the cam chain spring bolt and a small socket. That worked great for me.
Originally Posted by Isaac1022 View Post
i want to know too
