Steam rising from top of radiator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 01-28-2020, 11:25 AM Thread Starter
Hi!
I've noticed a condition where steam is rising up in front of the handlebars while riding lately. I can't imagine this is normal. Any ideas on what is causing this? My temp gauge doesn't register any reading at all either, and it's cold outside currently too.
Thanks in advance.
jakob_rothfuss is offline
post #2 of 5 (permalink) Old 01-28-2020, 02:00 PM
ubertalldude's Avatar
Definitely an issue, I'd say you need to look at the thermostat, check the thermometer wiring, and overall check the whole cooling system.
ubertalldude is offline
post #3 of 5 (permalink) Old 01-28-2020, 06:39 PM Thread Starter
Thanks. Will do. Any tips for troubleshooting? How long does it take for the temp gauge to rise/engine to warm up?
post #4 of 5 (permalink) Old 01-29-2020, 08:55 AM
It usually takes mine about 5 minutes of just idling for the temp gauge needle to start to rise. It won't get up to full temp for a couple of miles, usually. On cold days the needle may never get all the way to the halfway point, but on hot Florida summer days it just barely goes past the halfway point, that's what I consider "full hot"
As for troubleshooting, I guess just seeing if the radiator is full, if the water pump is flowing coolant, if the thermostat will open. It sounds like coolant is getting trapped somewhere and boiling off, which is creating the steam.
post #5 of 5 (permalink) Old 01-29-2020, 09:47 AM
In cool weather, mine can idle 10-15 min. before it reaches normal temp.
Are you sure it's steam? Your bike is earshaved, right? After I did it on mine, with the crank breather mounted beside the neck, once in a while I would see a bit of smoke passing in front of the headlight while stopped at a red light.
If it is steam, those o-rings on the coolant tubes at each head are prone to leaking.
