Valve Lash Adjustment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-21-2019, 05:44 PM Thread Starter
Jason Pittenger's Avatar
Is this a thing?
I'm removing my engine this winter to fix a coolant leak in the head gasket.
I'm trying to make a list of all the things to do while the engine is out.
So far, I have:
1. Replace Cylinder Head Gasket
2. Tuxedo Mod
3. Check/replace engine dampers
4. Remove surge tank (Airbox, not coolant overflow tank)
5. Valve Lash check/adjustment?
6. Anything else?
Completed modifications:
Planned modifications:
Last edited by Jason Pittenger; 10-22-2019 at 07:44 PM. Reason: Clarify meaning of "surge tank"
Jason Pittenger is offline
post #2 of 5 (permalink) Old 10-21-2019, 07:14 PM
Valve lash is hydraulic, no adjustment.
Why would you remove the surge tank? Antifreeze is slicker than greased owl poop under your tires.
post #3 of 5 (permalink) Old 10-21-2019, 08:55 PM
Isn't the surge tank and the breather box the same thing on this bike? Which everyone hates because it makes working on the carbs harder so they get rid of it when they do the ear shave (which I haven't done because I like the air pods)?
I thought it was only oil that would potentially come up into the surge tank, and that the coolant was its own enclosed system.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #4 of 5 (permalink) Old 10-21-2019, 09:31 PM
Yes, you're probably right. Always thought that was a silly name for the airbox.
The coolant tank is called a surge tank in some applications.
His signature says earshaved, maybe he left the airbox in?
post #5 of 5 (permalink) Old 10-22-2019, 07:48 PM Thread Starter
That'd be why I had never heard anyone mention this before!
PERFECT!
Ya, I was referring to the air box. I left the surge tank in while doing my earshave, because at the time, the only removal method I knew of was cutting it. I wasn't sure if I was going to keep it shaved, so I didn't want to destroy the air box.
