Ugly noise - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 18 (permalink) Old 09-01-2019, 09:19 PM Thread Starter
Newbie95 is offline
post #12 of 18 (permalink) Old 09-02-2019, 11:20 AM Thread Starter
So how screwed am i?
Newbie95 is offline
post #13 of 18 (permalink) Old 09-02-2019, 11:29 AM
Touch each ACCT and see if you can feel the tap stronger there.
I'm not convinced that is a rod knock so far.
It sounds like a louder version of what I hear with the stethoscope on mine, which has no problems. Same frequency and rhythm as best I can tell.
post #14 of 18 (permalink) Old 09-02-2019, 01:24 PM Thread Starter
Ok sounds good im not going to be messing with it now until i get the carb hangers in and get the vac leak under control i cant keep a consistent idle yet to to really dig in any further
Newbie95 is offline
post #15 of 18 (permalink) Old 09-02-2019, 03:37 PM
I should have said ... Touch the ACCTs and compare the vibrations there to vibrations at other points on the engine, like the valve covers and lower side cases on each side. I would think you could feel something that loud.
post #16 of 18 (permalink) Old 09-02-2019, 05:41 PM Thread Starter
Honestly listening with screwdriver and feeling around its still really tough to tell oil was pretty clean found one tiny magnetic shard and there are little flakes of aluminum so that has me worried if it is cam chain sprockets may be a bit chewed upand then it could be rod bearings
Newbie95 is offline
post #17 of 18 (permalink) Old 09-02-2019, 07:04 PM
Aluminum could be the chain guides or maybe the damper gear eating the side case.
post #18 of 18 (permalink) Old 09-03-2019, 12:04 AM Thread Starter
Thats what im figuring as well bit ove got not bad vibration just noise wont rule anything out just yet still waiting on hangers for the carbs
Newbie95 is offline
