Stumble at 3k rpm after new exhaust with rejet - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 2 Post By Spockster
post #1 of 9 (permalink) Old 08-03-2019, 09:33 PM Thread Starter
MSattler's Avatar
So I got a new set of Vance and Hines today. I put them on, and if I slam the throttle, it hesitates at 3k. If I go smoothly, thereís no problem. I put 140 jets with one shim in during the ear shave. How do I know how far I need to go up with the jets, without buying unnecessary jets? Thereís no exhaust leak that I could tell, and it worked great with the stock exhaust and even no exhaust
'08 Road King Classic
'86 VN750 with the following work done to it, after sitting for 19 years:
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #2 of 9 (permalink) Old 08-04-2019, 07:54 AM
Looks like you need to increase the pilot jet size to get a better transition from the pilot to the main.
post #3 of 9 (permalink) Old 08-04-2019, 11:28 AM Thread Starter
MSattler's Avatar
I may have 40/142. I canít remember. I do remember I have one shim though. I heard that the shim helps smooth the transfer between pilots and mains. Is that an option? It is still super rich, and when it does start, it fires up immediately with no choke.
So youíre thinking 42/142?
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #4 of 9 (permalink) Old 08-04-2019, 11:36 AM
Rich? That's some new info.
40 pilot? New info.
I can't imagine making it richer will help at all. But that all depends on the actual situation currently in place.
post #5 of 9 (permalink) Old 08-04-2019, 11:52 AM Thread Starter
MSattler's Avatar
40 pilot? New info.
I dug out the receipt.
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #6 of 9 (permalink) Old 08-04-2019, 01:01 PM
Almost everyone jumping to 42/142 has been too rich.
ubertalldude and MSattler like this.
post #7 of 9 (permalink) Old 08-04-2019, 02:36 PM Thread Starter
MSattler's Avatar
Which is consistent to the write up done. So should I try adding a second shim under the needles? Or no shims? I am surprised it didnít do this with no exhaust
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #8 of 9 (permalink) Old 08-04-2019, 04:18 PM
There's apparently enough restriction in the new pipes to make a difference.
Adding shims to the needles will make it richer. You can try to remove the shims and work from there, but you'll probably end up around 40/138-140. At any rate, you'll have to start over with the shims anyway.
post #9 of 9 (permalink) Old 08-04-2019, 04:43 PM Thread Starter
MSattler's Avatar
Okay. I will get those jets and let you know how it goes.
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
