Smoke from rear exhaust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-23-2019, 05:32 PM Thread Starter
I guess this fits in engine exhaust because I don’t think it’s electrical. I’ve seen other threads where people had this issue and the thread does without an answer. The space between the rear exhaust outlet and the frame I have smoke coming out (little). This is new since I took the motor out to change the stator. Nothing appears to be touching, the bike doesn’t sound like the exhaust is loose (used new metal o ring thing) and is torques to spec. Nothing is touching that I can see. I thought maybe it was from spraying wd40 or kroil to get things moving but it still does it after a while of running. I see no visible oil drip from head cover and feel no residue where I can reach.
The hard plastic like spacer in the engine block is the only thing I can think of but it’s back together as it came out so can’t think of why this would happen. Any suggestions?
I was considering pulling out the motor mount and seeing if it still does it.
N01290088 is offline
post #2 of 5 (permalink) Old 06-25-2019, 12:31 PM Thread Starter
The hard plastic spacers I’m seeing that fit exactly don’t show on the parts diagram could this be the issue?
post #3 of 5 (permalink) Old 06-25-2019, 12:40 PM
Not sure unless it's just lube burning off.
I think the spacers on mine were metal.
post #4 of 5 (permalink) Old 06-27-2019, 02:38 PM Thread Starter
These feel like black plastic very light for metal. I think my best bet is to pull that motor support let it run a few minutes idling and see if without the bolt or the spacers it does it.
Sound reasonable?
post #5 of 5 (permalink) Old 06-27-2019, 03:09 PM
Worth a try, see if the plastic looks melted. Did it smell like hot plastic?
