Second Coolant Leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 13 (permalink) Old 05-31-2019, 08:28 PM Thread Starter
Jason Pittenger's Avatar
Second Coolant Leak
I have another coolant leak, and I haven't fixed the first one yet! This one looks a bit more serious. Not in amount, but in location. It looks like the bottom of the cylinder is leaking! Is this fixable? Or should I just keep an eye on coolant levels?
ID:	45951   Click image for larger version
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #2 of 13 (permalink) Old 06-01-2019, 04:20 AM
The earliest way would be to take the petrol tank off and check all the connections and hoses from the filler cap down the aluminium thermostat housing could spring a leak with age it really is a simple job and not take long if there is nothing obvious connect a temp fual supply and check again with the bike running
water will always find its lowest point so you might have a pool at the bottom of the cylinders but it could be leaking from hose at the top
GDI likes this.
trev uk is offline
post #3 of 13 (permalink) Old 06-02-2019, 12:18 AM
Yes it could be running down from somewhere else. But if it is the cylinder base gasket, The whole top end will have to come off to fix it. This is an area where the engineers who designed the engine really messed up. The coolant passages are fairly large, and there is almost no gasket material around them. I can see even having a problem installing them without damaging them. They should have used more gasket material around the coolant passages. Don't put any kind of stop leak in the system, it will destroy the water pump mechanical seal.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 13 (permalink) Old 06-02-2019, 10:13 AM Thread Starter
That was what I was worried about. No leak stop, huh? Crap.
Well, looks like I'm going to just top it off all the time, till I part with this bike.
post #5 of 13 (permalink) Old 06-02-2019, 12:20 PM
You are making a mountain out of a mole hill the odds on the cylinder base gasket leaking must be 1000/1 it's probably something very simple unless you look you will never know
trev uk is offline
post #6 of 13 (permalink) Old 06-02-2019, 12:30 PM
Actually there have been several cases of base gaskets leaking. Again I believe it is bad design. The gasket surrounding the coolant passages is just not wide enough. However, I don't ever remember hearing about one blowing out. I would clean the engine off, then start it and let it run till the fan comes on, to build up pressure in the system, and see if you can find a coolant leak around the base of the cylinders.
1979 Vespa P200E
post #7 of 13 (permalink) Old 06-02-2019, 03:46 PM
I agree with look for the easy problem first.. check the thermostat housing (it does sit above the front cylinder). check the hoses going to it.
I had a leak there after I ear shaved, because I 'disturbed' one of the lines going to the housing. I only needed to remove the hose at the housing, clean off the corrosion from many years of neglect, new o-ring, and no leak
michiganteddybear is offline
post #8 of 13 (permalink) Old 06-02-2019, 05:24 PM
It just dawned on me your second leak is probably the first just getting worse
trev uk is offline
post #9 of 13 (permalink) Old 06-03-2019, 05:03 PM Thread Starter
Nah, the first leak is on the back cylinder on the opposite side. I'd be VERY surprised if it found its way around like this.
I'll check over it again carefully, but I didn't see any residue above the gasket location.
post #10 of 13 (permalink) Old 06-17-2019, 06:25 PM Thread Starter
5 more pictures.
ID:	46065   Click image for larger version
ID:	46067   Click image for larger version
ID:	46069   Click image for larger version
ID:	46071   Click image for larger version
