Coolant Leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 3 (permalink) Old 05-18-2019, 11:09 AM Thread Starter
Jason Pittenger's Avatar
Coolant Leak
Over the past couple weeks, I've noticed a faint hint of antifreeze smell while driving. I haven't overheated, and the total coolant level is still safe, so I wasn't overly concerned. Today, I found the leak! If you can't see in the picture, that is the left side rear cylinder head. It's leaking right where the coolant line comes into the cylinder head.
What's the best way to fix this?
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #2 of 3 (permalink) Old 05-18-2019, 11:52 AM
Pull the tube, clean the hole and the tube. Get a new o-ring, coat the tube with vaseline, re-install. I even put two o-rings on one tube, there's plenty of room.
GDI likes this.
post #3 of 3 (permalink) Old 05-18-2019, 04:37 PM
The rear coolant tube is prone to leak even when new. I've had 2 new VN750s, and noticed you could wiggle the tubes and they would leak slightly. There should be a tab welded to that tube that a bolt goes through to attach it to the head so it doesn't move around.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
