Restriction of Stock Exhaust With Ear Shave - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 11 (permalink) Old 05-03-2019, 12:22 PM Thread Starter
Jason Pittenger's Avatar
I intend this to be informative to people wondering about how removing the stock mufflers affect flow/tuning while keeping the Goats Belly. As I've read through this forum, I've had a hard time finding information on how the bike runs in my exact setup. Namely, an Ear Shave with the Goats Belly, and straight pipes after the GB. Many have the Ear Shave with stock exhaust, or Ear Shave with aftermarket exhaust, or stock intake and aftermarket exhaust. Not many appear to have done my particular arrangement.
Last night, in preparation to pull my carbs (again), I started and idled my bike to drain all the gas out. Since the only goal was to drain the carbs, I slid my mufflers back on to the GB to keep noise to a minimum. With my ear shave, 38/138 jets, 1 shim and 4 turns on the screws, this made it rich to the point of not needing the choke when cold. It also make the exhaust gas visibly black as it warmed up. I was amazed how much restriction it added at idle!
Removing the mufflers did not have this drastic of effect before the ear shave. Previously, pulling the mufflers had little to no change on the richness or idle speed.
Therefore, I would conclude:
1. The stock mufflers do not seem to have much restriction when used with the stock air intake.
Or more specifically, the stock intake is much more restrictive than the stock exhaust is.
Therefore, only removing the mufflers results in no needed changes to the tuning.
2. Doing an ear shave with the stock mufflers seems to lean out the mix a bit, but not a lot.
This seems to be the experience with people on the forum running 38 pilots with 132-138 mains with an ear shave and stock exhaust.
3. After an ear shave is complete, the mufflers become the most restrictive portion of the bike.
The combination is greater than the sum of the parts!
This seems to be the experience with people on the forum running 40-42 pilots with 140-142 mains with an ear shave and aftermarket exhaust.
4. The Goats Belly does not seem to have much restriction, and running straight piped after it is comparable to a full aftermarket exhaust.
Once I have my jets tuned in, I'll post back with my results.
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #2 of 11 (permalink) Old 05-03-2019, 01:51 PM
ear shave and stock exhaust in my case didnt need any change of jets, just adjusting the air bleed (idle mixture screw). which tells me that mine was properly jetted from the factory.
michiganteddybear is offline
post #3 of 11 (permalink) Old 05-03-2019, 08:37 PM
warbike's Avatar
I have the same setup on my Vn700, ear shave, goats belly and the the stock mufflers but baffles removed so basically straight piped after the GB. Only just recently got it running and I don't know what jets are in the carb so I don't have any experience with how it runs yet. I'll be interested to see what you end up doing with the carbs.
Sent from my moto z3 using Tapatalk
warbike is offline
post #4 of 11 (permalink) Old 05-03-2019, 09:59 PM
the thing to remember is EVERY situation is different. while mine was fine with stock jetting (I am at sea level), others with slightly different altitudes may need different jetting.
basically, just because it works for one person, does NOT mean it will work for you!
post #5 of 11 (permalink) Old 05-03-2019, 10:05 PM
warbike's Avatar
True, I don't know where Jason is located but if he let's me know at least above sea level attitude, I'll be able to adjust based on my +4000 ft level and fine tune from there.
warbike is offline
post #6 of 11 (permalink) Old 05-04-2019, 08:20 AM
GDI
Jason is down in Northern Illinois, so probably 750ft (just guessing).
GDI
GDI is offline
post #7 of 11 (permalink) Old 05-04-2019, 01:27 PM
You should also keep in mind that a less "restrictive" exhaust is not necessarily a good thing. The goats belly is referred to by Kawasaki as the "tuning chamber"... balancing out the exhaust pulses from both cylinders and providing the needed back pressure to provide the best compromise over the entire rpm range.
Straight pipes work fine for WFO operation, but not at speeds right off idle.
As much as the bike does love being opened up, many owners seem to prefer riding at lower rpms (this is one of the attributes of a "cruiser")
I also must mention that those with open pipes who claim gains in horsepower have not offered dyno data to support this, and seem to miss the idea that switching to simple straight pipes just removes a lot of weight from the bike, the entire stock system is freaking heavy.
roadpouring likes this.
post #8 of 11 (permalink) Old 05-04-2019, 10:40 PM Thread Starter
I also must mention that those with open pipes who claim gains in horsepower have not offered dyno data to support this, and seem to miss the idea that switching to simple straight pipes just removes a lot of weight from the bike, the entire stock system is freaking heavy. [IMG class=inlineimg]/forum/images/smilies/icon_wink.gif[/IMG]
This is why I left my GB on. (That, and I am too cheap/lazy to replace it 😉 ). I can't claim more HP or anything. I only observed that the stock intake is more restrict than the stock mufflers, and after an ear shave, the mufflers are restrictive enough to change the tuning. However, the mufflers are not restrictive enough on their own that removing them requires tuning changes.
I rode it today (briefly) with the mufflers back on, and it stumbled and bucked at WOT.
As a side note, I don't care for the ear shave intake noise with stock exhaust. I never heard it before, because I always had the mufflers off.
post #9 of 11 (permalink) Old 05-05-2019, 09:06 AM
Fired mine up with the mufflers removed, it hesitated bad off-idle.
post #10 of 11 (permalink) Old 05-06-2019, 06:52 AM
I can guarantee that a completely stock bike with the pilot screws turned out a little will be faster and make more power than a bike with modified intake/exhaust. More noise almost always equals less power. Running what amounts to an open intake and open pipes puts it beyond the tuning range of the carbs (one of the only advantages of EFI) An open intake and pipes is great for full throttle. That's why I run my drag race car with a K&N screen and open headers. It also has a tunnel ram manifold, and ported and polished heads, and a high lift long duration cam with a short ramp speed. All of that has one purpose. To get as much power out of it at high RPM. And since it has a carb, it does not run well at all at lower rpm, though putting a restrictive filter and a set of Flowmasters makes it drivable on the street, once you get the hang of it. I do not race my motorcycle, and would not want it to run that way. I want good low end torque and decent midrange. I don't ride it at full throttle. I always used the Vulcan 750 as a touring bike.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
