Page 1 of 2 | 1 | 2 |
oil leak problem
thanks in advance so i need to know how many oil drain plugs is on a 95 vulcan 750 i use the bottom drain plug but my cousin was helping me and said it has a side drain plug well he took it off and it broke but i can’t find anything on the side drain plug i would put pics in but he started jb welding it so i don’t leak oil
Sponsored Links | |||
There are two drain plugs. One on the bottom, and one on the side. The one on the side is part 11012-1483, and covers the internal oil filter/screen that protects the oil pump. There's a screen, washer, and spring that all get stacked in there.
Vulcan slang for newcomers
Service Manual Download
okay my cousin decided to jb weird it will that be a problem and got another question my pet coco is leaking from the face and i put a new o ring in it and it stopped for about a week and started pouring out of it again but the ring is still good no tear in it at all
Which oring did you replace? the one at the vacuum valve or at the face/selector lever?
Your housing may be excessively worn, scratched, have scuz buildup, the selector may be cracked, etc. If you've rebuilt it and it still leaks, chances are you just need to replace the unit.
fuel shutoff leaking
it leaking from the bottom of the face itself and i put a new o ring on the lever the old one was ripped but when i had the face off and with the new ring on it didn’t leak until i put the pressure ring in and the face plate back on
Hope the drain cap doesn't pop off while riding. An oiled back tire is a definite crash. Been there, done that, with a Goldwing.
it only leaks when the bike is off but when it’s running it don’t leak at all
Uhhhhhh, I no likey the sounds of JB weld in that area.....
Sent from my A502DL using Tapatalk
Originally Posted by Jesse Lynch
View Post
Post a picture of that side drain plug. You should not have any JB Weld around that. The side plug (near the sight glass) is the one you are supposed to use. I've had 3 Vulcan 750s, and never had that bottom plug out. I hope the case isn't damaged or the threads stripped where that side drain plug goes. If it is, you have a MAJOR problem. There are 5 pieces to that side plug. The plug itself, an O-ring, a strainer assembly, a flat washer, and a spring.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
