Cooling question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Chris and Shim
post #1 of 6 (permalink) Old 03-25-2019, 05:07 PM Thread Starter
Chevy65's Avatar
Cooling question
My bike is in it’s early restoration, well I filled it with distilled water too flush and when I went too take the bolt out of the side of the cylinder nothing drained out I’m kindve at a loss because I mashed the hoses and cracked the bleeder to get all the air out and it felt like everything was primed and water came out of the bleeder but still nothing. Any idea? Thanks.
Chevy65 is offline
post #2 of 6 (permalink) Old 03-26-2019, 01:13 AM
Wyattx's Avatar
Just did a coolant flush on mine and the vinegar and distilled water mix is how I went . Took awhile to get done due to running it till fan kicked on and then letting it cool before I went to next step but when I finally got to drain plugs on cylinders I noticed very little came out but it was distinctly vinegar water mix . So I just continued sorry I’m no help just thought I would share . 4 different drain locations figured I must of gotten it all through out the whole process.
Wyattx is offline
post #3 of 6 (permalink) Old 03-26-2019, 06:53 PM
I didn't get much, if any, from there when I flushed mine. It was all coming from the plug below the water pump, on the bottom of the right side of the engine.
post #4 of 6 (permalink) Old 03-26-2019, 10:37 PM
GDI
I don't remember any plug on the side of the cylinder. I just pulled the bottom radiator hose, and the plug on the bottom of the engine. Was enough sediment in the engine that nothing came out until I poked something in the hole. Seems like that is probably the most important one to get anyway. . . .
GDI
GDI is offline
post #5 of 6 (permalink) Old 03-27-2019, 10:28 AM Thread Starter
Chevy65's Avatar
Well kinda sounds like everybody gets the same results. Kinda had in the back of my mind like oh crap why is there nothing in the engine. Thanks everybody gave me alittle more piece of mind
Chevy65 is offline
post #6 of 6 (permalink) Old 03-29-2019, 11:52 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
There is a bolt on each cylinder to drain fluid that otherwise will get caught in the water passage. This is to drain what would not normally come out using just the main and radiator drain plugs. One pic below shows one with the bolt already removed and the other still has the bolt in.
The last pic shows about how much fluid to expect coming out.
Name:	RS Right side with plug removed.jpg
ID:	45699   Click image for larger version
Name:	RS Left side rear cylinder plug.jpg
ID:	45701   Click image for larger version
Name:	RS AMount from cyl water jacket drain plug.jpg
roadpouring likes this.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
