Another Goat belly - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-29-2019, 09:26 PM Thread Starter
Chevy65's Avatar
H pipe confusion
Quick question. Heard a lot of people talking about welding a pipe between the two exhaust pipes after the goat belly removal. What is the point in that? Sound? Performance? Just kinda curious to know the logic behind it
Chevy65 is offline
post #2 of 6 (permalink) Old 01-30-2019, 12:16 AM
kryptonianjorel's Avatar
I've seen no need for it
kryptonianjorel is offline
post #3 of 6 (permalink) Old 01-30-2019, 05:58 PM
SkyPilot's Avatar
It's a crossover, theory is a sharing of exhaust/vacuum pulses that help keep exhaust gas velocity up and help empty the combustion Chambers wall the opposite exhaust valve is open... Sometimes called exhaust scavenging.
A true X-pipe would be the only way to gain enough scavenging across a wide enough RPM band to reap any real world benefit.
SkyPilot is offline
post #4 of 6 (permalink) Old 01-30-2019, 06:50 PM
It helps on V8s, on V-twins, not so much.
Harley did it some engines.
Not really worth it unless you're drag racing for money.
post #5 of 6 (permalink) Old 02-08-2019, 08:52 PM
Peanut571's Avatar
https://www.enginelabs.com/engine-te...gn-and-theory/
I suggest this as a read, it pretty much explains everything about exhaust in vehicles.
Unless you are going for performance, having a merge pipe or crossover is usually good for balancing or smoothing out the exhaust sound.
Peanut571 is offline
post #6 of 6 (permalink) Old 02-15-2019, 03:03 PM
1stVulcan750's Avatar
On the topic of goats... I just took mine off and crossed the rear exhaust to the right side. I used two right angle pipes and will have a shop weld in a y pipe I cut and a cheapo emgo muffler. As it sits both exhaust are the same length and are waiting till Monday. Has anyone else done a 2 -1 have any of you ran the 750 with just pipes? I'm questioning if it would be alright to ride around still.
1stVulcan750 is offline
