Old cooling system - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-27-2019, 04:30 PM Thread Starter
Chevy65's Avatar
Old cooling system
I bought my 86 a couple weeks ago and the past owners have not takin care of her at all. Out in the rain parts layin in the dirt etc. anyways the coolant resivore was empty and has what kinda looks like algae in it. How can I flush the entire system? From resivore, radiator and all the little passages in the engine? Just want to make sure everything is clean and open.
Chevy65 is offline
post #2 of 7 (permalink) Old 01-28-2019, 10:38 AM
ubertalldude's Avatar
You can remove the reservoir and wash it out, then you can run a chemical flush if you want, otherwise there's a drain plug on the bottom of the engine, one at the bottom of the radiator, and one near the base of each cylinder jug. Flush with distilled water to your heart's content, then refill with coolant that states it's safe for aluminum engines. Typically I think this is yellow coolant nowadays, at least that's what I put in my engine last time. Engine ice is supposed to help if you're in higher temp areas. Like oils, there's endless discussion on every forum about what the BEST fluid is, but so long as it's aluminum safe and you burp/bleed the system you'll be OK.
ubertalldude is online now
post #3 of 7 (permalink) Old 01-28-2019, 02:30 PM Thread Starter
Chevy65's Avatar
Will probably just use distilled water “to flush”. “Not use the chemical flush” Less chemicals to have to worry about, the better in my mind. Thanks for the response. Much needed info. I saw all the discussion one says yea used it for years then the next is ranting about how it’s horrible kinda leaves me scratching my head. I’ve got a bottle of prestone extended life cor-guard. Says good for all engines. And good/bad reports?
Chevy65 is offline
post #4 of 7 (permalink) Old 01-28-2019, 02:43 PM
NewB to Vulcans
TonyO's Avatar
Coolants have all sorts of corrosion inhibitors in them that are necessary, plain water will cause severe corrosion in the bike
'99 Vulcan "Victoria"
TonyO is offline
post #5 of 7 (permalink) Old 01-28-2019, 02:47 PM
yup, only thing worse than straight water is no water
not only corrostion inhibitors, but also lubricants for the water pump
michiganteddybear is offline
post #6 of 7 (permalink) Old 01-28-2019, 03:34 PM Thread Starter
Chevy65's Avatar
Edited my last post, wording was misleading and confusing. Thanks again for the responses!
Anybody used prestone extended life cor-guard. Says good for all engines. Just wanted a review before I trashed my bike
Chevy65 is offline
post #7 of 7 (permalink) Old 01-28-2019, 11:47 PM
kryptonianjorel's Avatar
Flushing the bike with distilled water (Not tap water) will not harm it in the least if you're going to be putting coolant back in it soon.
Are you referring to the overflow tank? I've found that the nastiness of that tank does not correspond to how clean or dirty your coolant is. I had a tough time cleaning mine out and eventually used a pressurized water stream to get it clean inside
kryptonianjorel is offline
