Crankcase breather pipe location. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-22-2019, 04:05 PM Thread Starter
Hi guyís just bought a 750 as a winter project.Ive done an ear shave and for the life of me canít find the engine crankcase breather.After removing the air box/surge tank I have a rubber hose the runs down the rear oh side of the radiator but itís not connected anywhere (presumably the top was connected to the surge tank). I have a filter to fit but nowhere to fit it. Spent half an hour with a torch but no luck finding the pipe. I have noticed a bit of oil on the engine covers so maybe the pipe has been disconnected a while. Can anyone point me in the right direction. ? Thanks guys.
Martync is offline
post #2 of 9 (permalink) Old 01-22-2019, 04:51 PM
front cylinder, on front side of it, on left side of front face (when sitting on bike). small stubby pipe that sticks out.
normally the hose for it connects directly to the surge tank.
michiganteddybear is offline
post #3 of 9 (permalink) Old 01-22-2019, 04:52 PM
Insert a 3/8" fuel hose into the original breather hose and clamp it. Run the fuel hose to the spot you want to mount the filter. Depends on the filter you have, of course. Mine is mounted to a bolt where the right side air filter used to be (earshaved).
Or, some just mounted the filter onto the original vent hose, having a filter that fits that larger hose.
post #4 of 9 (permalink) Old 01-22-2019, 05:10 PM
Oops - As MTB said, the nipple for the crankcase vent is just above the oil filter.
post #5 of 9 (permalink) Old 01-22-2019, 07:25 PM
Originally Posted by Martync View Post
.... After removing the air box/surge tank I have a rubber hose the runs down the rear oh side of the radiator but it’s not connected anywhere (presumably the top was connected to the surge tank). ....
That was a drain hose for the airbox. About a 1/4" - 3/16" hose.
post #6 of 9 (permalink) Old 01-23-2019, 03:57 PM Thread Starter
Well, been hunting the elusive breather outlet again. Researched where it should be and seen photos on the web. Where I was expecting to find it is plugged. It looks like a factory thing. Ive attached a photo, am I having a total blonde moment or should the pipe be here? Looked around the oil filter (lower down) and pulled the radiator forward to get a better view and can't for the life of me see the crankcase vent. The bikes a Spanish model (std European) but I'm sure theres no variation between US and Europe. ?
Martync is offline
post #7 of 9 (permalink) Old 01-23-2019, 04:04 PM
You have it circled there, but definitely looks like it's plugged.
Have no idea if there's a difference with Euro models. Most engines need some form of crankcase vent, but that looks factory.
Did it have the 5/8" elbow hose on the airbox, or the hole in the airbox for the hose? Here's one with the hose attached:
post #8 of 9 (permalink) Old 01-23-2019, 04:18 PM Thread Starter
I have found the hose behind the rad with a larger diameter portion of pipe at the top but I canít confirm where the top of the pipe was attached,I suspect the surge tank, but that got destroyed,kicked around the garage and jumped on when it finally came out. I suppose I could machine a new oil filler cap with an integral breather tube to make sure the crankcase vents. I know the European models have 110 main jets and USA and Canada have 135 so maybe there are other differences
Martync is offline
post #9 of 9 (permalink) Old 01-23-2019, 04:25 PM
Someone must have capped the hole. I can't see the factory allowing unfiltered air into the airbox. If you had the hose, it had to be connected on the airbox, but the engine is definitely capped.
Might be able to remove the cap? Then press fit a nipple for hose attachment.
I did learn about the Euro carb jetting, from a poster here a couple months ago, surprised me.
