Removing the Engine! need some help. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #1 of 25 (permalink) Old 01-07-2019, 01:03 PM Thread Starter
Hello everyone (wow i keep on making threads) Your help has been invaluable up untill now with electronics and repairs.
And since I need to replace my stator and dont have a mod I need to undertake what is in my mind my biggest challenge yet, removing the engine from the frame!
And could use some help from you guys. This is the current state of my progress and will continue tomorrow morning.
https://ibb.co/k9Phqt8
https://ibb.co/yN5mgZ3
https://ibb.co/TL4xWwx
https://ibb.co/Thgfh3Q
I was wondering what i still have to undertake in order to be able to remove the engine from the frame. Especially how and if I need to remove the shaft drive. And if I can place something underneath the engine and then let it sit on it after removing the bolts that connect the engine to the frame without breaking something I forgot.
(I know people use service manuals to do these kinds of jobs and i have a haynes manual but it doesnt state this job and how to do it)
Name:	WhatsApp Image 2019-01-07 at 15.54.43.jpg
ID:	45349   Click image for larger version
Name:	WhatsApp Image 2019-01-07 at 15.54.44.jpg
ID:	45351   Click image for larger version
Name:	WhatsApp Image 2019-01-07 at 15.54.43(3).jpg
ID:	45353   Click image for larger version
Name:	WhatsApp Image 2019-01-07 at 15.54.44(1).jpg
ID:	45355   Click image for larger version
Name:	WhatsApp Image 2019-01-07 at 15.54.43(2).jpg
Name:	WhatsApp Image 2019-01-07 at 15.54.43(1).jpg
Panarock is offline
post #2 of 25 (permalink) Old 01-07-2019, 01:35 PM
Have you considered just tilting the engine? There's a lot less to remove/disconnect that way. I was glad I did, since I had to do it twice in two days due to a mistake I made the first time.
Floor jack under the engine is a must, and tie the centerstand forward so it can't fold back.
There's a download for another service/parts manual in my signature.
Edit: Never mind the tilt, I see it still has the airbox, so unless you want to remove that, I don't think it will tilt. Removing the airbox in one piece requires disconnecting the rear section of the wiring harness and pulling the harness forward out of the frame
Throttle cables are one item yet to be removed.
I don't have any experience with pulling the engine, but when I tilted mine, I left the bevel gear case, exhaust manifolds, and throttle cables all on the engine.
post #3 of 25 (permalink) Old 01-07-2019, 02:19 PM Thread Starter
I have, this was the plan I had, but dont know how, do i lift the front end of the engine? or do i move the engine to the right side out of the frame to get to the stator box?
Also, do i need to remove the crankshaft from the engine? I imagine this is connected to the engine right?
And how do I do this?
+ can i leave the throttle cable on? Since i dont know if it needs a sync once i put em back on.
Panarock is offline
post #4 of 25 (permalink) Old 01-07-2019, 02:43 PM
See my edit below on tilting.
Pulling the engine completely out, carb cables have to come off. Driveshaft can stay in, but I'm pretty sure you have to take the bevel gearcase off.
post #5 of 25 (permalink) Old 01-07-2019, 03:34 PM Thread Starter
Oh im planning on tilting the engine like you did. sorry that wasnt so clear in the previous message. Can i leave the gearcase and rear shaft thing when tilting?
Panarock is offline
post #6 of 25 (permalink) Old 01-07-2019, 03:44 PM
Yes, bevel gear can stay on the engine, driveshaft stays in. Airbox will have to come out. And you'll need at least two ratcheting tie downs.
See if this is any help, some pics there: https://www.vn750.com/forum/19-elect...ancer-job.html
post #7 of 25 (permalink) Old 01-07-2019, 04:06 PM Thread Starter
Awesome that helps alot! Thanks!
Panarock is offline
post #8 of 25 (permalink) Old 01-08-2019, 09:41 AM Thread Starter
So i got rhis far, engine is as good as loose from the frame, but cant seem to remove the case of the stator, what am i missing?
Panarock is offline
post #9 of 25 (permalink) Old 01-08-2019, 10:43 AM
ubertalldude's Avatar
That's what the whole "engine tilt" process is. Spockster did a good writeup with pictures. You need to get the engine far enough away from that left frame rail that you can slip the stator case past the shift shaft. Personally I found it to be about the same work to just remove the engine, which is what I did.
SergheiS likes this.
ubertalldude is offline
post #10 of 25 (permalink) Old 01-08-2019, 11:05 AM
Location: southern, western, middle Tennessee backwoods
https://www.ebay.com/sch/i.html?_fro...=impact+driver
If the screws are stuck, you need one like this.
Check local auto supply.
Get a slender one and you can use it on the carb screws.
Be sure it's set to ccw and not clockwise or you risk breaking the screws.
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is offline
