Earshave Without Coasters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 2 (permalink) Old 12-03-2018, 03:31 PM Thread Starter
Jason Pittenger's Avatar
Question Earshave Without Coasters
I'm working on the earshave on my bike.
I'm following this procedure with one exception.
I want to keep the stock reed valves, because I like the popping on decel.
The separator VALVE,AIR SWITCH has one vacuum hose, two hoses that go to the cylinders, and one hose that went to the surge tank.
How critical is it that this intake hose is filtered air?
Can I leave it open, or is that just asking for trouble?
Would a Emgo filter have sufficient flow with it's 3/8" output when the air hoses are 3/4"?
3/4" is 4 times the area of 3/8".
Or is there a better solution for this?
Thanks!
'89 Vulcan 750 Bought 4/12/18 @ 17805.9 miles $800
Purchased stock. Wrecked once
22490.0+ miles
Completed modifications:
Removed mufflers, straight pipes out of GB
110/90 Front Tire
Pick-up coil re-gapped to .020"
Compufire 55402 r/r series regulator
USB Outlet + Voltmeter
Repainted Metallic Blue w/ new tank bages
Ear Shave (wo/ coasters) 40/140 NO shims 45MPG
MCCT conversion
Planned modifications:
Custom LED turn signals
Highway Pegs
(Possible) ignition advance
Jason Pittenger is offline
post #2 of 2 (permalink) Old 12-03-2018, 04:14 PM
Filter will probably flow enough, it's not a huge volume of air at all. Make a spitting noise against the back of your hand, it's about that much inside each head. Without filter, there's a chance of dirt/moisture passing through the head port.
You could probably coaster and maintain the pop by adjusting the air screws inward. Haven't touched my air screws and it doesn't pop. Another way might be disabling the coast enrichers, mine did pop right after the mods, and I think it was the enrichers being stuck. A day with seafoam stopped the popping. Less rubber spaghetti with coasters.
On mine, coastered and shaved, if I open the vacuum port on the left carb during long decels, it goes off like a cannon, but just one time. Loud enough to possibly split a muffler.
Jason Pittenger likes this.
Tags
coaster , earshave , mod
