Idling issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-31-2018, 03:50 PM Thread Starter
Idling issue
Only have this issue when the bike is fully warmed up. When I知 coming to a stop I値l put it in 1st gear. When I知 slowing to around 5 mph the idle will rise to 1500 then I stop it drops down and dies. It値l idle fine if I put it in nuetral. It only dies in gear at a stop. The clutch cable moves freely and is properly adjusted. I am at a loss wondering if anyone has had this issue .
97 Kawasaki vulcan 750
2015 Honda CBR650F
Both all stock
Collyz85 is offline
post #2 of 6 (permalink) Old 10-31-2018, 09:26 PM
What happens if you hold the clutch lever in while stopped in first gear?
If it still runs, are you able to slowly let out the clutch? Can you feel any friction between the engine and the clutch? Does the bike want to move at all, etc? There's an electrical switch at the clutch lever. Does the engine dying have any relationship to the 'click' sound the clutch lever makes as that switch engages/disengages?
Thorn is online now
post #3 of 6 (permalink) Old 11-01-2018, 01:25 AM Thread Starter
It値l die if I keep the clutch lever held in. It feels like the clutch is still slightly engaged with the lever pulled in. Shifting from nuetral to 1st drops the rpms down and it wants to go forward. Once you hit the brakes to stop it it値l die
2015 Honda CBR650F
Both all stock
Collyz85 is offline
post #4 of 6 (permalink) Old 11-01-2018, 02:06 AM
kryptonianjorel's Avatar
you might have your answer then. Could be that the clutch is still slightly engaged when the lever is pulled in
kryptonianjorel is offline
post #5 of 6 (permalink) Old 11-01-2018, 05:18 AM Thread Starter
I値l most likely have to look at the clutch basket to see if there痴 excessive grooves
2015 Honda CBR650F
Both all stock
Collyz85 is offline
post #6 of 6 (permalink) Old 11-01-2018, 08:44 AM
Assuming it won't die if you hold the throttle open? Does sound like your clutch is not disengaging fully. Try adjusting it for zero play in the cable and see if that helps....if it does, then there's a problem with the clutch.
