Warm engine will not start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 13 (permalink) Old 09-07-2018, 01:50 PM Thread Starter
Help I have a problem.
When my engine is cold, it is very easy to start and drive. The engine also run smootly both in idle and speed. But when the engine is warm and I stop it for a few minuts, it is almost impossible to start it again. I can turn the starter engine 15-20 seconds without the engine will start (sometime it will start). If I wait 40 - 45 minutes, I can start it again without problem.
I have try to use the choker, but that does’t help.
The spark plugs is new and they looks great after driving a long distance.
I have also check the ignition coal; all four makes a nice blue spark over 10 milimeters.
I have try to remove the airfilter, but that does’t help.
Finaly the cabs are newly synchronized but, that was before I discovered a crack in one of intake rubber boots. Both of the rubber boots have been change now, so maybe the synchronizing is not so good anymore, if the crack was there, during the synchronizing. But the engine run smootly, as I wrote.
Any ideas would bee mostly welcome.
Preben59 is offline
post #2 of 13 (permalink) Old 09-07-2018, 02:05 PM
Your battery is the likely cause. Is it a fairly new AGM ? If not, it should be .....
post #3 of 13 (permalink) Old 09-07-2018, 02:07 PM
Search the forum for 'pickup coil mod'.
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #4 of 13 (permalink) Old 09-07-2018, 03:26 PM Thread Starter
I have a brand new batteri
Preben59 is offline
post #5 of 13 (permalink) Old 09-07-2018, 05:38 PM
Is it a common wet cell? Batteries can go bad, even new ones..
How are you trying to start it when warm? (Removing the airfilter of using the choke wouldn't help) The starter should only run 3 seconds for each try. If your holding it for 20 seconds you're straining the battery.
post #6 of 13 (permalink) Old 09-08-2018, 03:09 AM Thread Starter
Yes it is a acid batteri.
I hold the starter in 5-8 second severel time
Preben59 is offline
post #7 of 13 (permalink) Old 09-08-2018, 09:28 AM
as already mentioned, the best battery for these bikes are AGM type lead acid batteries.. they dont have any way to add water/electrolyte after manufacture, as they are sealed. the standard lead acid battery has fill caps for topping off electrolyte/water.
also already mentioned is the pickup coil mod. to the best of my knowledge, everyone who has done it, no longer has warm/hot start issues.
the pickup coils from factory are set a country mile from the flywheel/magnets.. after mod, they are set to .020". I think on mine the coils where set to about .060" from factory, which is huge for a magnetic pickup gap.
michiganteddybear is offline
post #8 of 13 (permalink) Old 09-08-2018, 11:12 AM Thread Starter
Very interesting and usefull. I will try to modify the pickup coil and returne the result 👌 Thanks a lot
Preben59 is offline
post #9 of 13 (permalink) Old 09-09-2018, 01:09 PM Thread Starter
Hi everyone
I have now mod. my pickup coil to 0.02”. THAT HELPS A LOT 😁 Thanks to you all friends
Thorn likes this.
Preben59 is offline
post #10 of 13 (permalink) Old 09-11-2018, 09:53 AM
When the engine is hot, no choke and 2/3 of full throttle. This always works with my 750 Vulcan.
Finn Ziem is offline
