no oil pressure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-17-2018, 06:29 PM Thread Starter
no oil pressure
After getting the engine out and with the side covers off, I can see that the oil pump is turning and the chain that drives it is intact, what else could cause the pressure to drop to nothing, could it be an internal oil ling broken? RCM
rcm243 is offline
post #2 of 3 (permalink) Old 08-17-2018, 06:41 PM
Did you check the pressure by putting a gauge at the oil switch? ... Yes, you did ... https://www.vn750.com/forum/31-engin...-pressure.html
It's possible the pump itself is just worn out. The gear fit is very precise and too much clearance is what makes them fail to pump.
There's been some trouble with oil changes and needing to burp the filter to turn the oil light off, but I don't know if that can also stop pressure from building in the engine. (wouldn't think so) Have you cranked it any with the oil sender fitting open, nothing threaded into it? It would suck to find out it needed burped, but at least you wouldn't have to split the case.
post #3 of 3 (permalink) Old 08-17-2018, 07:01 PM Thread Starter
It was ok and the next time I started it the light was on and I put a gauge in it , no pressure, I wouldn`t think the pump would go quickly because of wear, I`ll find out when I split the cases.
rcm243 is offline
