nut on clutch housing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-17-2018, 12:28 PM Thread Starter
Is the 30mm nut on the clutch outer housing right or left hand. RCM
rcm243 is offline
post #2 of 4 (permalink) Old 08-17-2018, 12:42 PM
JETHRO's Avatar
it is standard ie - lefty loosey, righty tighty, but this is a self locking nut and can be a bitch to undo , I had to cut mine off, even a windy gun would not remove it
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #3 of 4 (permalink) Old 08-17-2018, 02:35 PM Thread Starter
I used an impact and got the nut off, thanks for the info. RCM
rcm243 is offline
post #4 of 4 (permalink) Old 08-19-2018, 06:44 AM
JETHRO's Avatar
this nut should only be used once and they are not that expensive to replace
JETHRO is offline
