99 with a leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-15-2018, 06:25 PM Thread Starter
Vman99's Avatar
Question 99 with a leak
Hi all this is my first post. I have a few problems. I purchased my bike about 1 year ago. It had been sitting. I got it running somewhat and then it sat again. I sent it the shop almost a month ago now and they got it running. Said it needed a carb kit and a wire fixed and the pet cock fixed. Now after he got it running the hard lines coming out of the cylinder heads are leaking. Is that just a regular 14mm o ring or is it a square cut o ring? And I was told that a regular round 14mm o ring should seal it even if it was a square cut in there. Hope all the info I gave helps!
Vman99 is offline
post #2 of 5 (permalink) Old 08-15-2018, 07:50 PM
It's just a round o-ring. I ended up using a 5/8" or so.
Good idea to coat them with grease, there's some corrosion that occurs there with the steel tube in the aluminum head.
post #3 of 5 (permalink) Old 08-16-2018, 07:18 PM Thread Starter
Vman99's Avatar
Any other tips? The shop said they “Couldn’t get it to seal. Still pissing bad”
Vman99 is offline
post #4 of 5 (permalink) Old 08-16-2018, 07:24 PM
Make sure everything is clean and as smooth as possible, and use a generous coating of waterproof grease.
I've noticed a lot of the coolant tubes with fairly heavy corrosion and pitting that might cause sealing problems. Make sure there's no white clots of corrosion stuck in the head. If the tubes are pitted bad, the pits will have to be filled or the tubes replaced.
I think you can even double up on o-rings if needed.
post #5 of 5 (permalink) Old 08-28-2018, 06:54 PM
vulkan's Avatar
Funny I had to read most of the replies to figure...its a water leak!!Thought at first you were talkin oil!!
vulkan is offline
Tags
coolant leak , vn750
