Intermittent RPM drop - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 12 (permalink) Old 08-02-2018, 04:41 PM Thread Starter
ateam's Avatar
Exclamation Intermittent RPM drop
Hi Vulcan owners,
I have developed strange fault and seek advice to see if itís normal.
Intermittently when I stop at a junction or lights, if I hold the clutch in the rpmís drop to 800rpm almost sounding like it will stall, if I put it into nutreal and release the clutch the rpms go back up to 1100rpm, this only happens once or twice on my journey to work most of the time it holds the 1100rpm.
Does anybody else have this problem or do you have a suggestion to cure this.
Many thanks for your help.
ateam is offline
post #2 of 12 (permalink) Old 08-02-2018, 05:16 PM
Is the clutch dragging when it happens? Cable getting ready to break?
Was thinking vacuum leak or dirt hitting the pilot jets, but it doesn't happen all the time. .. and going to neutral speeds it up.
post #3 of 12 (permalink) Old 08-02-2018, 05:20 PM
Followup to Spockster's question about it possibly being a dragging clutch: if you put it in neutral and keep the clutch lever pulled, does it stay at 800?
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #4 of 12 (permalink) Old 08-02-2018, 05:23 PM
Worn or improperly adjusted clutch. Try adjusting the play in the clutch lever.
(You can adjust the cable so there is NO play in the cable and see if it solves the problem.. if it does, you have a worn or warped clutch plate(s))
If rpms are dropping while it's in gear, the clutch plates are not disengaging completely...
post #5 of 12 (permalink) Old 08-02-2018, 06:02 PM Thread Starter
ateam's Avatar
Hi all,
Thanks for the replies.
The revs still drop even in neutral with clutch pulled, it doesnt affect the bike while cruising, just when I stop and pull the clutch in nuetral or with a gear selected and lever pulled.
It doesnít do it every time, but I will adjust the clutch cable at the weekend.
ateam is offline
post #6 of 12 (permalink) Old 08-02-2018, 08:40 PM
mine would drop rpm when the fan kicked on when at a light, but it didnt drop that much, only 100-150 rpm drop.
JETHRO likes this.
michiganteddybear is offline
post #7 of 12 (permalink) Old 08-03-2018, 04:19 AM
JETHRO's Avatar
yes MTB with a slightly weak battery this would cause it, also there is the clutch basket mod which can eliminate drag and coffee grinding noise.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #8 of 12 (permalink) Old 08-03-2018, 01:15 PM
Originally Posted by ateam View Post
Hi all,
Do the cable adjustment first, but it's possible there's a weak short to ground in the clutch switch wiring (aka lockout switch) causing a drain on the electrical system when the lever is pulled. Never heard of that happening, but it's strange that the rpm drop happens when the bike is in neutral since that should remove clutch drag as a cause.
ateam likes this.
Thorn is online now
post #9 of 12 (permalink) Old 08-03-2018, 04:33 PM
kryptonianjorel's Avatar
Could a general bad ground connection somewhere cause this to happen?
kryptonianjorel is offline
post #10 of 12 (permalink) Old 08-03-2018, 04:38 PM
Well the clutch lever does have a switch in it. You could check there to start.
ateam likes this.
