front cylinder removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-31-2018, 05:57 PM Thread Starter
does anybody know if the front cylinder on my 1990 vn750 can be removed in frame so that i can replace the base gasket,or have i got to take the motor out, cheers
johngee is offline
post #2 of 3 (permalink) Old 05-31-2018, 10:35 PM
ubertalldude's Avatar
unless you have done the earshave (airbox and stock air filter delete) then you'll almost certainly have to remove the engine to pull the jug
ubertalldude is offline
post #3 of 3 (permalink) Old 06-01-2018, 11:58 AM
Birga's Avatar
Sorry to say you'll have to pull the motor. The head studs go into the block, so to get the jug off yo have to lift it clear of those. or back them out after you pull the head and leave them running through the jug.
Birga is offline
