Chrome Stripping Idea - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By Spockster
  • 2 Post By Jason Pittenger
post #1 of 9 (permalink) Old 05-05-2018, 05:07 PM Thread Starter
Jason Pittenger's Avatar
I have a friend that used muriatic acid to strip the chrome off his Harley exhaust, leaving a yellowish nickel finish. It's a really nice classic look. Would this work for the vn750 chrome parts, or am I just asking for trouble?
My pipes have already turned yellow and blue up near the cylinder, so the goal is a bit more consistent color, and classic look.
'89 Vulcan 750 Bought 4/12/18 @ 17805.9 miles $800
Purchased stock. Wrecked once
22490.0+ miles
Completed modifications:
Removed mufflers, straight pipes out of GB
110/90 Front Tire
Pick-up coil re-gapped to .020"
Compufire 55402 r/r series regulator
USB Outlet + Voltmeter
Repainted Metallic Blue w/ new tank bages
Ear Shave (wo/ coasters) 40/140 NO shims 45MPG
MCCT conversion
Planned modifications:
Custom LED turn signals
Highway Pegs
(Possible) ignition advance
Jason Pittenger is offline
post #2 of 9 (permalink) Old 05-05-2018, 10:11 PM
GDI
Muriatic acid can be some pretty mean stuff, but I'm no chemist so I would only be guessing what effect it might have on your pipes. The yellow and purple that you're seeing is oxidation. There are products available to remove that oxidation if that's what your underlying concern is. See https://www.amazon.com/Simichrome-42.../dp/B0022ZOR78 , which is one that I've heard of, but there are probably others as well.
There is no bluing on my pipes. The stock pipes are double-wall, and they really don't blue very easily. Bluing can be a symptom that is caused by a lean fuel mixture, though I guess a rich mixture can cause the same thing? Point is that if your bike is running right, you shouldn't have an issue. Aftermarket pipes are a different story because they may only be a single wall, which blues much more easily. Depending on your situation and your preferences you have some options, but just be aware that if your pipes are blue, then the "Blue Away" may not do much for you because it may be a symptom of how your bike is running.
GDI
GDI is online now
post #3 of 9 (permalink) Old 05-06-2018, 06:53 AM
I would polish the discoloration out as GDI stated. I did the same on mine.
If you are getting discoloration, then you need to fix the problem and not the symptom....carb adjustments are needed.
Now...as far as stripping chrome off....You can use Easy Off oven cleaner to accomplish that task.
post #4 of 9 (permalink) Old 05-06-2018, 01:32 PM Thread Starter
As far as discoloration, I don't know the bike's full history. I have put on 500 of it's 18,000 miles. The pipes came discolored. It probably had an issue before, but the most recent owner took good care of it. It seems to be running fine now.
I was just exploring cosmetics at this point
22490.0+ miles
110/90 Front Tire
MCCT conversion
Highway Pegs
post #5 of 9 (permalink) Old 05-10-2018, 09:38 AM
It would be very rare to find a set of stock pipes without some discoloration, especially near the heads on the downpipes.
I used chrome polish, then wax, though I don't know how long wax will last with the heat. On chrome that doesn't see heat extremes, it's always best to wax after polishing. Most of the blue polished out, and the yellow lightened up a lot.
A lot of riders embrace the color, say it adds character, so they wear it proudly.
WilliamTech3 likes this.
post #6 of 9 (permalink) Old 05-10-2018, 12:22 PM Thread Starter
I started looking around at other bikes' pipes, and almost all have it.
I think I'll leave well enough alone! Thanks!
ubertalldude and lugnut1009 like this.
22490.0+ miles
110/90 Front Tire
MCCT conversion
Highway Pegs
post #7 of 9 (permalink) Old 05-31-2018, 12:25 PM
Used Easyoff to strip the paint from my gas tank and chrome pieces yesterday. Was under the impression it wouldn't react with the chrome, glad I didn't leave it on for too long!
Jumpstreet is offline
post #8 of 9 (permalink) Old 05-31-2018, 12:55 PM
Are you talking about the side covers? They are actually chrome paint...
post #9 of 9 (permalink) Old 05-31-2018, 01:33 PM
previous owner had blacked everything, including gas tank, exhaust pipes, chrome frame/sissy bar, lights, forks etc. (did strip paint from plastic covers accidentally).
