Removed Mufflers - - Results - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #11 of 27 (permalink) Old 05-03-2018, 05:10 PM
POP POP POP POP POP POP
post #12 of 27 (permalink) Old 05-03-2018, 11:50 PM
Diesel Tech
DenverDiesel's Avatar
How are the stock mufflers restrictive? They are straight through and good diameter, there are no baffles!
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #13 of 27 (permalink) Old 05-04-2018, 11:05 AM Thread Starter
Jason Pittenger's Avatar
The stock mufflers have a single baffle on them. I can't say how restrictive they are, but they do have a baffle.
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #14 of 27 (permalink) Old 05-10-2018, 04:41 PM Thread Starter
Here are pictures with the muffler's removed.
Sorry for the delay, my phone stopped being able to log in!
Name:	image-20180428_170414 - Copy.jpg
ID:	44122   Click image for larger version
Name:	IMG_20180508_1842380 - Copy.jpg
ID:	44130   Click image for larger version
Name:	image-20180428_170433 - Copy.jpg
ID:	44138   Click image for larger version
Name:	IMG_20180508_1843578 - Copy.jpg
ID:	44146   Click image for larger version
Name:	IMG_20180508_1844094 - Copy.jpg
post #15 of 27 (permalink) Old 05-10-2018, 05:11 PM
Looks like shorty megaphones.
I fired mine up like that one time, I thought it sounded like an atv, thump-thump-thump. Didn't ride it though.
Watch the plug color to see if it goes lean.
I see pairs of HD mufflers pretty often. $10-20 plus shipping.
post #16 of 27 (permalink) Old 05-11-2018, 12:13 AM
ubertalldude's Avatar
looks surprisingly clean with the heat shields installed. I'm curious to hear how it sounds, might have to give it a try sometime!
ubertalldude is offline
post #17 of 27 (permalink) Old 05-13-2018, 12:43 PM
WilliamTech3's Avatar
Cool
....your passenger's shoe soles will melt !
She'll refuse to ride with ya.....might as well put a solo seat on the beast.
WilliamTech3
Jason Pittenger likes this.
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
post #18 of 27 (permalink) Old 05-29-2018, 11:12 AM Thread Starter
So a few weeks of riding without mufflers, I have an updated review.
It sounds really good below 3.5k! At about 4k, the individual pops start blending together. As a result, I've found myself lugging the engine if I shift by sound. I have to force myself to keep RPMs above 3k. Because of its HD resembling sound, it's a bit odd to wind it out to 8.5k. With Harley's falling flat at 5500, it sounds like I'm over revving the engine! It definitely sounds bigger than it is. It's sound matches its performance now.
At cruise, the engine noise is audible above wind noise (I wear a full face helmet), but not objectionable. It's no more fatiguing than the wind noise is. For rides over 30 minutes, I prefer to have ear plugs, but that was true with the mufflers on. At 60 mph, the engine's so lightly loaded that there's not a huge amount of noise. At 80 mph, you can hear the engine pushing. It increases in volume about as much as the wind noise increases from 60 to 80. I feel more in tune with what the engine's doing, simply by being able to hear it at cruise.
Pulling the mufflers means the heat shields lose one of their mounting points. Make sure the other two clamps are tight. There's not a lot of clearance between them and the passenger foot peg mounts and that's where they shake and rattle the most! I ended up shifting the shields a bit to gain clearance, as well as gently & slightly bending them away from the mounts.
WilliamTech3
For better or worse, she already has no desire to ride with me. Her loss!
I like the Mean Streak seat...I might put one on.
post #19 of 27 (permalink) Old 05-29-2018, 11:44 AM
I love the sound of these motors with opened up exhaust at higher rpms
post #20 of 27 (permalink) Old 06-25-2018, 05:42 PM Thread Starter
Yesterday, I was told from a non-biker that my bike doesn't sound like an HD, but sounds Japanese. I pressed for more explanation, and he said "it's missing some low end, and you don't sound like a complete #*@-hole".
On the topic of not being an #*@-hole, for morning rides, I start my bike in the garage (doors closed, while I stand outside) and let it warm up, before I leave. My driveway slopes down into the garage, so I either have to wait until I don't need choke, or I have to wind out to 3k rpm. I keep acceleration at a minimum until I'm out of the neighborhood. I don't want my neighbors to hate me.
I have noticed I don't get deceleration pops after full throttle runs. However, I do get them coming off of cruise. Could I be a bit lean on the main jet?
Some have discussed how removing back-pressure might cause a loss of torque. To be more concise, it is the tuning of pressure waves that result in added (or lost) torque. The expansion of the pipe causes a negative pressure wave to travel back to the cylinder. This negative pressure causes scavenging of exhaust gasses, resulting in more efficient burning (and more torque). I looked at the stock mufflers, and the pipe size expands right before the baffle, and right at the point that my pipes now end. So the pulse timing should be almost identical to factory tuning, and thus there shouldn't be any torque loss. I cannot confirm this with dyno runs, however. The removed baffle should (in theory) give a bit better flow and a bit more power over the entire rev range (more so at high RPM). Again, I have no dyno data to confirm it.
