Ringing noise - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 13Likes
post #11 of 29 (permalink) Old 06-25-2018, 03:36 AM
In all seriousness, try taking your key off the keychain.
kryptonianjorel likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #12 of 29 (permalink) Old 06-25-2018, 06:52 AM
lugnut1009's Avatar
Mine wasn't quite that noticeable. But I did figure mine out, it is/was the gas tank mount on the left side, the washer vibrates against the tank lip. I could hold pressure on it and it quits. Yours sounds very distinct, almost like a piece of sheet metal or something small tinging.... Hmmmmm....
-2016 Indian Springfield
Chieftain bars
Roadmaster heated seat
-1999 Kawasaki Vulcan 750
Ear shaved
Mufflers removed / 38/140 + 2 shims
Relay coil mod
Pick-up coil mod
Emissions removed
Lowered rear
Rear blinkers located in tail light housing
Petcock gutted
- Wife's: 2018 Can-am Spyder F3 Limited Pearl White
lugnut1009 is offline
post #13 of 29 (permalink) Old 06-25-2018, 08:01 AM Thread Starter
Diesel Tech
DenverDiesel's Avatar
Its absolutely not the key, or anything I can put my hand on topside. Tank mounts are secure. I have driven without the dash panel so its not the gauges either.
I haven't run without the gas cap, maybe the key mechanism is doing it.
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #14 of 29 (permalink) Old 06-25-2018, 08:39 AM
NewB to Vulcans
TonyO's Avatar
When first got mine it did a similar thing. The Exhaust Shield was cracked in a couple places allowing it to rattle. Wrapped the splits with Aluminum Tape and it stopped.
'99 Vulcan "Victoria"
TonyO is offline
post #15 of 29 (permalink) Old 06-25-2018, 04:31 PM
couple of things to check:
Right side brake lever - vibration causing the inside shoe guard to contact the exhaust possibly.
Heat shields
Front Brake cables vibrating against the handlebars or cluster...same for clutch cable
Rear brake cable rattling in the area of the coolant bottle.
Rubber stop missing on center stand...vibration causing it to "ting"
Throttle cables routed near the right side of the frame neck. there is a loop the cables go through under the neck cover. There is also a "spring" around the cables. either of those could rattle at RPM and make a noise.
And last but not least.....connectors in the headlight bucket rattling. This one took a while to find.
post #16 of 29 (permalink) Old 06-25-2018, 08:58 PM
ubertalldude's Avatar
that's far louder than mine, but mine has been intermittently getting louder and changing pitch for years. did you do the earshave? I have to wonder if (ruling out all other loose parts, of course) it might just be the sound of the valvetrain through the pod filters I have... in your case though, that seems less likely. Mine is more of a tap with a ring, yours has a very definitive tone to it
ubertalldude is offline
post #17 of 29 (permalink) Old 08-05-2018, 07:42 AM
bUMrider's Avatar
Hi did this get solved yet? I got my first VN750 the other day and I have the same wierd noise going on. I can't for the life of me figure it out.
EDIT: Could it be the cooler fan?
Freedom is two wheels on the ground
Last edited by bUMrider; 08-05-2018 at 08:00 AM. Reason: Added an idea of what the noise could be
bUMrider is offline
post #18 of 29 (permalink) Old 08-05-2018, 08:04 AM Thread Starter
Diesel Tech
Half of it was the gas cap lock. I took it apart and put an o-ring between two of the mechanism sections and it solved that.
There is still noise coming from the front end somewhere that I can't isolate.
1989 VN750
Highway blaster
1982 Mercedes 300D
post #19 of 29 (permalink) Old 08-05-2018, 02:59 PM
kryptonianjorel's Avatar
I know this wasn't your problem, but my tach shakes like a mother------ at 2000 RPM. Doesn't do it higher or lower RPMs though. Maybe its just something random a little loose and nothing to worry about?
kryptonianjorel is offline
post #20 of 29 (permalink) Old 08-05-2018, 06:42 PM
readparse's Avatar
Originally Posted by shark88 View Post
I had a ringing noise once and it was the license plate vibrating.
Funny, I had a similar noise. it wasn't from the plate itself, but from a washer that was too loose to do any good anyway. It had really been bothering me during rides (not a great time to troubleshoot exactly where a noise is coming from), but when I was back there doing something, I hit the license plate and realized it was that stupid washer.
Off it came! And I haven't looked back. I sure am glad I got rid of that noise.
I still have a little rattling from my gauges, but I've worked around that by riding with my helmet that has a little more padding around the ears
readparse is offline
