Never Trust the PO's Mechanic - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-04-2018, 05:29 PM Thread Starter
Birga's Avatar
So, I split the case to fix my oil leak at the seam above the oil filter. and low and behold the likely reason for the leak.
and the other side
so my question is, is the case still useable? I do have another lower the I can clean up that I think is good so there is that.
also I can confirm the engine will run smoothly while missing the two odd balance dampeners.
Birga is offline
post #2 of 5 (permalink) Old 04-05-2018, 04:12 PM
black coffee
chokingvictim's Avatar
geez dude thats a real ****ty discovery make I'm sure you could quiksteel it back together and file down the excess,can't run any worse than before.
2002 vn750
hocked goat
single carb
dope ass suicide shifter
hand clutch
emmisions axed
bitchin stereo
permanent trailer containing charging system
beer cooler backrest
chokingvictim is offline
post #3 of 5 (permalink) Old 04-05-2018, 04:57 PM Thread Starter
Birga's Avatar
Just got back with the Quick Steel actually. I debated brazing it instead, but don't want to overheat it with oxy acetylene and don't want to buy a map gas torch.
If anyone wants a specific picture of anything inside let me know in the next week or so, I'll be happy to get it for you.
Birga is offline
post #4 of 5 (permalink) Old 04-06-2018, 04:06 AM
Diesel Tech
DenverDiesel's Avatar
The water pump drive. My shaft has about 1/2 turn of free rotation and I want to know if thats normal.
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #5 of 5 (permalink) Old 04-06-2018, 01:47 PM Thread Starter
Birga's Avatar
with half a turn of rotation it sounds like the impeller shaft is messed up.
Here is the water pump drive on the back of the oil pump.
and the shaft to the impeller.
Birga is offline
