No oil in the sight glass - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 11 (permalink) Old 03-10-2018, 05:14 PM Thread Starter
Changed my oil put 4 quarts of oil in it and I don’t see anything in the sight class should I add more oil the bike is on it center stand I’m not able to start the bike because I have the carb pulled and rust in the tank
Jerry West is offline
post #2 of 11 (permalink) Old 03-10-2018, 05:44 PM
Are you sure it isn't showing overfull? Should be an air bubble at the top once the level is correct. 4qts with a filter change, and not started, it would look overfull.
With no oil, you should be able to see the silver case, and some of the cast lines in it.
Use a flashlight and see what you have.
Paulywog likes this.
post #3 of 11 (permalink) Old 03-10-2018, 07:37 PM
Thought I would give you a heads up for after you get it running .....
The oil in this engine gets "air entrainment" on cold starts. If you start it cold, run just a minute or two, then shut it off, the oil in the sight glass will look milky like it has water in it. That's normal and goes away after the oil gets hot.
post #4 of 11 (permalink) Old 03-10-2018, 08:44 PM
typical change with filter is just shy of 4 qts.. LIke said above, it might be over full
michiganteddybear is offline
post #5 of 11 (permalink) Old 03-11-2018, 03:02 PM
WilliamTech3's Avatar
Lightbulb
...maybe if taken off center stand, lean the bike to the right a bubble may appear.
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
post #6 of 11 (permalink) Old 03-11-2018, 08:53 PM Thread Starter
This is what I got after 4 qts
ID:	43185   Click image for larger version
post #7 of 11 (permalink) Old 03-11-2018, 09:33 PM
Mod
Birdhunter02's Avatar
Yep. Over filled. See the brown tinge? Should be clear if empty.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #8 of 11 (permalink) Old 03-11-2018, 09:49 PM Thread Starter
I’m sorry I don’t follow brown tinge ?
post #9 of 11 (permalink) Old 03-11-2018, 10:01 PM
The brownish tinge when you look at the metal in the sight glass. It should be completely silver if you were out of oil
snoopyonderdonk is offline
post #10 of 11 (permalink) Old 03-11-2018, 10:05 PM
Red face
...fresh new oil will appear as brownish......no (low volume) oil, should appear as clear.
Since May 2011
