Water pump play - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-17-2018, 12:27 AM Thread Starter
Diesel Tech
DenverDiesel's Avatar
Water pump play
Is it normal for the water pump to have 1/2 turn of free rotation?
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #2 of 5 (permalink) Old 02-17-2018, 12:10 PM
I recall some lateral play being normal, verified by others here. Never tried to rotate the impeller, I assumed it was direct gear-drive and wouldn't move much.
Pretty sure the oil pump is chain-drive ... Not sure about the impeller now.
post #3 of 5 (permalink) Old 02-17-2018, 02:37 PM
JETHRO's Avatar
The oil pump is chain driven which in turn drives a spindle which is split in half and joined together to run the water pump. It has a simple slot and key joint so can be taken apart during tear down, If one side of the spindle has broken off this would create the half turn you stated .....not good but is the screw loose on impeller ? I would remove it and check threads.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #4 of 5 (permalink) Old 02-17-2018, 03:10 PM
JETHRO's Avatar
Just thinking about your prob, The impeller fits on shaft by a staggered joint this may have worn also .I would take it off and give a good clean and see if there is any rounding off of parts.
JETHRO is offline
post #5 of 5 (permalink) Old 02-18-2018, 12:17 AM Thread Starter
Diesel Tech
The nut was tight and there is no play in the shaft. I replaced the impeller and mechanical seals.
I ran the engine today and it is pumping.
1989 VN750
Highway blaster
1982 Mercedes 300D
