New/Used Fuel Tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By OleDirtyDoc
  • 2 Post By kc2dgq
post #1 of 7 (permalink) Old 08-03-2017, 09:30 PM Thread Starter
New/Used Fuel Tank
My Vulcan's been sitting for awhile. Yes, I know, bad girl. I bought a set of (new to me) carbs that were cleaned before shipping. I took it to a guy to have the carbs put on and he told me that there's rust in my gas tank. Should I buy a (new to me ) tank or is there a way to salvage mine? Does anyone have one for sale? Any help is appreciated. Thanks.
Summer
summer is offline
post #2 of 7 (permalink) Old 08-03-2017, 10:02 PM
long time no see.there's a few threads in the Vulcan Verses. I'm trying to find one on electrolysis used to clean the rust up but haven't found it yet, but I will later
post #3 of 7 (permalink) Old 08-03-2017, 11:51 PM
I do have a 2003 tank, burgundy/gray metallic, clean inside /out, except the left side has a knee dent and a fall over on the trailer crease. Took it off last Spring. I always parked the good side out, and pretended my leg covered the dents.
New tanks go $250-400 on ebay. I was able to find a new black/silver met., factory sealed.
Doc remember that thread last month, the guy was trying the electrolysis, we told him to make sure the bolt didn't touch the tank. He had a forum link to some of the electrolysis info, thought that link was in the Verses..
post #4 of 7 (permalink) Old 08-04-2017, 01:09 AM
yup that is the link I'm looking for
post #5 of 7 (permalink) Old 08-04-2017, 01:14 AM
https://www.vn750.com/forum/42-body/1153-rust-tank.html and here it is
Thorn likes this.
post #6 of 7 (permalink) Old 08-05-2017, 02:22 PM
I highly recommend using the POR-15 products to clean and coat the inside of fuel tanks.
LINK
I had a rusty tank I had to clean up and re-coat because the PO used that crap KREEM which was a mess in the tank and the rust was developing under the plastic coating while the coating itself was peeling away from the tank.
I used a few gallons of acetone to dissolve the Kreem liner and threw in a few dog collar chains.....shook and rotated the tank to get rid of the old coating and remove the loose rust.
Then I used the POR metal prep. it chemically changes the rust to a zinc phosphate coating which will prevent flash rusting while you dry the inside of the tank, plus it preps the surface for good adhesion of the POR tank liner.
It worked very well and was not expensive...just follow the directions and don't skip any of the steps to save money.....it will cost you in the long run.
OleDirtyDoc and jgs000 like this.
post #7 of 7 (permalink) Old 08-05-2017, 04:44 PM
Yes. POR-15 good...Kreem bad. Cheaper than a new tank and once done should never rust again.
