Harbor Freight Motorcycle lift - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 16 (permalink) Old 02-26-2017, 10:15 PM Thread Starter
NewB to Vulcans
TonyO's Avatar
Does anyone know if this will fit the Vulcan?
1500 lb. Capacity ATV/Motorcycle Lift
My back is killing me from replacing the water pump seals.
'99 Vulcan "Victoria"
TonyO is offline
post #2 of 16 (permalink) Old 02-26-2017, 10:21 PM
haven't used that particular model but it looks similar to mine so it should
post #3 of 16 (permalink) Old 02-26-2017, 11:29 PM
jgs000's Avatar
Location: elmira ny, great place to ride, no jobs though
its ok , its not great, will leak down overnite without the stops.
jgs000 is offline
post #4 of 16 (permalink) Old 02-27-2017, 02:16 AM
mine leaks down as well
post #5 of 16 (permalink) Old 02-28-2017, 01:33 PM Thread Starter
NewB to Vulcans
TonyO's Avatar
Thanks, hopefully it spends most of its life folded up and put away.
DACataldo likes this.
TonyO is offline
post #6 of 16 (permalink) Old 02-28-2017, 02:31 PM
I have one, doesn't have the fancy handle you have to crank with your feet but mine lifts my sporty without any trouble whatsoever so yep, it will easily lift the Vulcan. Any vulcan for that matter. BUT, when I had a center stand, I'm thinking of any reason to have had one. I could get both wheels off when needed so. Only got one when I got the sporty cause of this very issue. Also my sporty is super fast so....it's just faast man....FAST!
post #7 of 16 (permalink) Old 03-02-2017, 05:10 PM
I share the last question. What is the benefit of a lift? I have removed both wheels at the same time to change tires on the center stand.
-Robert
RobertGary1 is offline
post #8 of 16 (permalink) Old 03-02-2017, 09:33 PM
-Robert
sanity while removing both wheels
post #9 of 16 (permalink) Old 04-03-2018, 12:51 PM
I have the same exact one, and yes it will lift it, only problem is that the engine sits lower than the frame so I made some blocks it could sit on that have a half circle cut into them so the frame sits instead of the engine. It really came in hand for removing the engine. Again blocks and then just roll it out.
ubertalldude likes this.
MikeIronTyson is offline
post #10 of 16 (permalink) Old 04-03-2018, 08:58 PM
WilliamTech3's Avatar
Wink
EDIT of below: just checked mine.....it is a "Big Red" 1500lb....appears exact same as HF jack, but has added lift/carry handle front & rear and only a foot pedal for jacking.
Same here as above......
Got mine @ Goodwill.....non-functioning--- +Saturday Special w/ 50% discount--.... $10.00 !
Harbor Freight Hydraulic Fluid = $5.99 .....15 minutes ....all set.
This jack I purchased UNUSED....not a scratch in paint or a sign of oil/grease !
Tested on automobile....held w/o issues..... (3-4 hours ?)
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
