tach trim ring/bezel - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-26-2015, 10:09 PM Thread Starter
nhsmoker's Avatar
Can anyone tell me how to remove the metal bezel around my tach mine is very very dented/ crushed and I would like to remove it to either replace or at least reshape. glass and everything is fine somehow but the trim is toast.
nhsmoker is offline
post #2 of 9 (permalink) Old 07-26-2015, 11:36 PM
Only the housing comes off, they are a sealed unit. Buy one of eBay if yours is bad.
post #3 of 9 (permalink) Old 07-27-2015, 08:40 AM
I took mine off to get to the inside of my gauge unit...
email me for more info.. I can't post a link to my document.
post #4 of 9 (permalink) Old 07-27-2015, 06:47 PM Thread Starter
nhsmoker's Avatar
the metal ring is sealed to the glass?
nhsmoker is offline
post #5 of 9 (permalink) Old 07-28-2015, 10:34 AM
no its not sealed to the glass, there iss a rubber seal between the glass and the white plastic housing.. the chrome bezel keep pressure against the glass to seal it up.
post #6 of 9 (permalink) Old 07-29-2015, 10:35 PM
did my page help?
post #7 of 9 (permalink) Old 07-30-2015, 07:24 PM Thread Starter
nhsmoker's Avatar
did my page help?
havent tried it yet. I assume you do the same process as the guy does with the speedo on whatever kind of bike that the video was made for?
nhsmoker is offline
post #8 of 9 (permalink) Old 07-30-2015, 11:00 PM
if you got a video, it wasn't my page.. I wrote up a whole paper on doing this to a Honda Shadow 1100. but yes the process is the same no matter what bike you are working on.
post #9 of 9 (permalink) Old 07-31-2015, 10:29 AM
93VN750's Avatar
FWIW, I sanded my trim rings clean, masked the glass and everything below the rings and spray painted them gloss black. I think it looks good.
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
