Handelbars Bent - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-07-2015, 08:13 PM Thread Starter
gaittec's Avatar
Handelbars Bent
I bought a 2003 Vulcan 750 with a noticeable bend in the bars from when it fell off the side kickstand while parked on a downhill slope. So, I ordered another bar off ebay. The new (salvaged) bar came in and it also has a very slight bend on the same side. Can I correct it without weakening it too much? It is at the first bend and probably 3 or 4 mm in one direction. If so what is the best way to do it? Thanks
gaittec is offline
post #2 of 7 (permalink) Old 05-07-2015, 09:30 PM
I straightened mine when they were slightly bent. Someone told me they would break and fall off, but they've last a few thousand miles. As long as the bar isn't kinked.
I found fixed points to measure from.
Got creative with a hand full of 2" ratchet straps, pickup truck, and heavy lawn tractor.
Put the bike on the centerstand, sideways and close to the back bumper of the truck, parked the lawn tractor on the other side of the bike.
Strapped the bike to the truck, positioned the tractor so the strap would pull the right direction (on the tractor side).
Kept pulling and re-checking measurements, pulled just slightly past where it needed to be, and took the strap off. It was perfect.
Need make sure you're not pulling the bike off the centerstand, the two vehicles were just anchors, the strap did the pulling.
post #3 of 7 (permalink) Old 05-29-2015, 06:33 PM Thread Starter
gaittec's Avatar
Thanks for the reply. Since I posted, I've noticed a lot of vibration (more on the bent side) and I think I'm going for a new steel bar, gel grips, and a vibration dampening insert/end cap.
It's not bad to ride now,; but the old carpal tunnel is coming back.
gaittec is offline
post #4 of 7 (permalink) Old 05-29-2015, 07:20 PM
A large bench vise and a four foot cheater bar can do wonders....
Had as set of clubman bars that one side was bent. Figured what direction I needed to go, traced the angle needed on a large piece of graph paper and lacking the big vise, stuck the other part of the handle bar into the frame of a garage door. Kept tweeting it with the 4 foot pipe and checking it for symmetry against the paper till it was spot on.
Was a good three inches out of whack to start with, but never had the bar break on me.
(Oh, kinda fuked up the garage door frame...big hammer fixed it)
post #5 of 7 (permalink) Old 05-29-2015, 10:16 PM
i knew you had some redneck in ya lol
post #6 of 7 (permalink) Old 05-29-2015, 10:28 PM
Maybe when he was in prison
post #7 of 7 (permalink) Old 05-29-2015, 10:34 PM
i wasnt going to go that far doc
