Viking Saddlebags - Some questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 04-03-2015, 11:40 PM Thread Starter
AndrewGilbert's Avatar
I have been looking for some storage solutions on my new-to-me 750. Having no previous knowledge about saddlebags before this weekend I have had to play the catch-up game. My brain is hurting from the sudden influx.
So, I had a couple questions about the Viking brand saddle bags. They seem to be the best option for me because of where they line up on the price vs. quality spectrum. I also like that they are rated very well for water resistance(and seem to receive good reviews to support that too). My question is how do they stay water tight with four large holes drilled in the back of them? I get that two will accept a mounting bolt, but two will not. And why do some bags have the four pre-fab'd holes and some models do not? It doesn't look like there is a method to why they would produce mounting holes in one model and not the other. I don't know, maybe I'm just thinking about it too hard.
Also, when I look at the rear fender, the passenger backrest support seems to be right where you would want to place the stirrup for throw-over mounting. I would prefer that, as opposed to bolting to the supports, but it looks like it may not be easy to route the crossover stirrup level. I don't want wonky bags. Nope.
I just put on an OEM saddlebag support kit this afternoon that I snagged off eBay so I'm really trying to figure out what is going to work out the best.
I am pretty sure there was at least one good question in there. Feel free to answer as many or as few as you like. Thanks.
2006 Vulcan 750
Bone Stock
2000 Honda XR650L
Wiseco 10.4:1
Pirelli Scorpions
AndrewGilbert is offline
post #2 of 26 (permalink) Old 04-04-2015, 06:25 AM
Deviate's Avatar
I'm assuming that all viking bags are the same. I bought some for my Stryker, but I had some el cheapos from LeatherUp.com on my Vulcan. My bags are the warrior universal bags and can be throw-over or hard mounted.
The four holes are for positioning the bags front or back more depending on how you want them. There are bolts on the parts that connect for using the bags as throw-overs and they go in two of those holes. The other two holes have a plastic plug in them. In my case, viking sent 4 plastic plugs for each bag so you can plug all of the holes when hard mountings and still keep the bags water resistant.
As far as where the bag falls across the rear fender...on my vulcan I had modified my seat and added a backrest from a honda 1100. The strap for the bags did fall a little bit across where the stock backrest support would have been. I also had to relocate my turn signals because they would have been in the way too.
I didn't use bag supports on my vulcan. I just had them resting on the shocks and tied down as best I could to keep them from moving.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 26 (permalink) Old 04-04-2015, 08:47 AM
I don't have Vikings, but also placed the throw-over strap partially up on to the grab rail/back support. Turned out to be a nice fit, with the strap forming a gentle curve versus kinking up. The strap is also under the seat.
I used supports and no bolts, since the bags have four D-rings for tiedown. Two ties in front to the frame, two in back tied to a bracket on the license plate, which also is a mount for aftermarket turn signals. The ties have Quicklinks on the ends for easy removal, the bags are zip off design, so I don't have to remove the saddle strap.
I made sure to mount them high enough to clear the mufflers, with a little extra in case the saddle stretches. been good so far, but I haven't put much weight in them yet.
Not the best pic, but you can see some of the saddle strap against the backrest:
post #4 of 26 (permalink) Old 04-04-2015, 08:55 AM
I had a set on my old 750 and liked them pretty well. Check out the slanted Chargers with the shock cut out on the back if you want them to fit tight to your bike. Ol Dog had a set of those on his sportster and they looked pretty good!
post #5 of 26 (permalink) Old 04-04-2015, 09:14 AM
heaney750's Avatar
what ever u do stay away from the brand diamond plate there bags suck balls just look at mine and youll see
heaney750 is offline
post #6 of 26 (permalink) Old 04-04-2015, 08:59 PM Thread Starter
Thank you, guys, for the comments.
Deviate, that makes a lot more sense when you explained things. Thank you.
I have the supports on now, so I'm looking at the universal bags w/out the shock indentation.
I think if I go with them, which is likely, that I will get the sling-over kit and try that. If I hate it I can just bolt them onto the supports.
Thanks, all.
2006 Vulcan 750
Bone Stock
2000 Honda XR650L
Wiseco 10.4:1
Pirelli Scorpions
post #7 of 26 (permalink) Old 04-04-2015, 09:15 PM
Mod
Birdhunter02's Avatar
You'll be much more happy with the hard mount, in my opinion. The throw overs can sag and tilt. Though they are easier to remove.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #8 of 26 (permalink) Old 04-04-2015, 10:51 PM
Mine either eats bags or burns them
OleDirtyDoc is online now
post #9 of 26 (permalink) Old 04-05-2015, 09:34 PM
Kevinf's Avatar
Just took my saddlebags off. Bike looks much sleeker that way, and I have a backpack that rests comfortably on the stock seat
Kevinf is offline
post #10 of 26 (permalink) Old 08-05-2015, 08:51 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I just got some Viking bags delivered today. The turn signal relocation kit hasn't arrived yet but since I have no time to play with it anyway for the next week, it's no big deal. I haven't any personal experience installing bags so this will be a first for me. I plan to hard-mount them. We've had a recent death in the extended family which will result in my time being spent in other activities for the next "X" amount of time so I've got a bit before I need to squat down, scratch my head, and figure out how to attach the support brackets.
Chris and Shim is offline
