Anyone used the Harbor Freight Tire Changer? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 01-28-2015, 04:02 PM Thread Starter
GloryRider's Avatar
Just picked one of these up...
http://www.harborfreight.com/manual-...ger-69686.html
With the motorcycle adapter...
http://www.harborfreight.com/Motorcy...ent-60810.html
Has anyone used one of these??
I'm thinking to use Ride-On as my "balancer"...
Any thoughts?
Thanks!
Matt
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #2 of 22 (permalink) Old 01-28-2015, 04:16 PM
I think Mercury has one.
post #3 of 22 (permalink) Old 01-28-2015, 05:33 PM
I'd still balance using weights...even if you use Ride On.
post #4 of 22 (permalink) Old 01-28-2015, 11:49 PM
Balance? We don't need no steenkin balance
post #5 of 22 (permalink) Old 01-29-2015, 12:45 AM
I had a tire that I had balanced two or three times and no one ,including me, could get it right. I had read a bunch on the Dyna beads , and i am here to tell you even without the weights they work and work well. I haven't tried the Ride on sealant so I can't speak to that.
I have that same tire changer and haven't bolted it down yet but it has to be easier than c-clamps and tire irons, I'll let you know next week as I have two to change out both on Hondas, one tube type and one tubeless
post #6 of 22 (permalink) Old 01-29-2015, 04:57 AM
Ndr
I use that tire changer and it works pretty good for me
To make it REALLY shine though I would HIGHLY recommend some upgrades.
I would get the Mojo Lever and Mojo Blocks
Lever: http://home.comcast.net/~prestondrake/mojoweb.htm
Blocks: http://home.comcast.net/~prestondrake/mojoblocks.htm
The Blocks insert into the tire/rim clams and allow a much more secure clamping down of the wheel with no marring if the wheel shifts at all (which it will)
Without the blocks, the tire will have a tendency to pop UP out of the clamps. The blocks hold the wheel down. Though you will still need to use a tie down strap to keep the wheel from spinning.
The lever is WONDERFUL. Allows you to pull the old tire off and pop the new one on in under 5 minutes. It has no mar tips on it, and it infinitely better then the lever that comes with the tire changer.
The lever also allows you to do the removal and install with no tire spoons.
Video of some guy using the HF setup with the MoJo add ons:
https://www.youtube.com/watch?v=AuH5BzAR4a4
another video of a guy using the Mojo lever on a car tire: (note, the Mojo lever instruction say not to do this)
https://www.youtube.com/watch?v=MGzrJSTSoXk
As for balancing..o each their own for that. I've been using Ride-On only with no weights for a few years now and in my opinion, its give a much better balance then weights can.
Ndr is offline
post #7 of 22 (permalink) Old 01-29-2015, 04:59 AM
Ndr
Also,
If you can bolt the tire changer directly to a concrete floor, it will make things so much easier.
Otherwise, the stand wants to wobble all over the place when attempting to remove install the tire.
Ndr is offline
post #8 of 22 (permalink) Old 01-29-2015, 09:52 AM
Never had a problem getting any tire off the wheel and have used the HF changer to mount new tires on VN750s and KLR. But, had no luck mounting bigger tires. I was able to mount Metzelers on my 750 but could not get Metzelers mounted on the Nomad rear and ended up having the HD dealer down the road mount 'em. Just seemed like I was gonna tear/damage the tire??. I bolted the changer to a hefty pallet which worked out OK for me.
johnrwilco is offline
post #9 of 22 (permalink) Old 01-29-2015, 10:59 AM
The reason I suggest balancing with weights THEN using Ride On ...is because It's a liquid. If the tires balance is off, the majority of the liquid will flow to only one side of the tire....meaning if you pick up a nail on the other side you're not getting the full benefit of the sealant.
If you balance using weights and at least get it real close, the sealant will distribute more evenly in the tire.
post #10 of 22 (permalink) Old 01-30-2015, 01:59 AM
Ndr
Well that makes a lot of sense. Honestly hadn't thought about that.
Ndr is offline
