Can someone help me identify this? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-05-2014, 12:03 PM Thread Starter
I have no idea what these are... they look like speakers? maybe?
cpeter58 is offline
post #2 of 10 (permalink) Old 09-05-2014, 12:05 PM
your fancy dandy dual horns that the Vulcan have..
so in a sense, yes, speakers
michiganteddybear is offline
post #3 of 10 (permalink) Old 09-05-2014, 12:10 PM Thread Starter
haha ok thanks for the help
cpeter58 is offline
post #4 of 10 (permalink) Old 09-05-2014, 12:17 PM
Look like little titties
post #5 of 10 (permalink) Old 09-08-2014, 03:06 AM
Yep, those are Ma Kaws little meep, meep roadrunner horns.
Doesn't everybody know by now that the smallest most vulnerable vehicles need the loudest horns!!
I replaced mine with a pair of Fiamm Freeway Blasters that tend to get errant cagers and inattentive pedestrians attention when I have to use them. They are really just standard rams horn shaped car horns bolted on in front of the bike, right where the anemic OEM meep, meep horns were. The plain black color looks good to me.
Still looking for a space on the left side of the frame to mount a Wolo or Stebel Nautilus compact air horn too,
post #6 of 10 (permalink) Old 09-08-2014, 08:07 AM
Did you re wire for those horns?
I know some pull more power than the stock ones and need heavier wire or seperate fusing...
Nice to see you posting here again 'Hoss....
post #7 of 10 (permalink) Old 09-08-2014, 09:32 PM
Yeah, the horns are powered with 14 ga wire direct from the battery thru a relay. The OEM wiring would not even coax a strangled meow out of them. lol Just used that switched horn wire for a trigger to the relay.
post #8 of 10 (permalink) Old 09-08-2014, 10:26 PM
AngryBob's Avatar
I bought a pair of those FIAMM Highway Blasters as well, but stock wiring can't use the pair. I'm just using one, and I sealed the leads for the other horn with electric tape.
Definitely gets people's attention over the stock meeptacular horns. ^_^
"wanting people to listen, you can't just tap them on the shoulder anymore - you have to hit them with a sledgehammer. and then you'll notice you have their strict attention"
AngryBob is offline
post #9 of 10 (permalink) Old 09-09-2014, 01:22 AM
My horn is broken .watch fir middle finger.not very loud though .
OleDirtyDoc is online now
post #10 of 10 (permalink) Old 09-09-2014, 11:04 PM
Horns draw a lot of juice. 3 - 8 amps I believe. Best to use a relay with a large wire to reduce voltage drop
Merc
2000 Vulcan Drifter 800
Roadhouse classic 2 > 1 exhaust
Okie Smokie intake config
Changed jets
52K miles or so, always going up
Corbin Seat
Painted flat black winter '12
Mercury is offline
