Trunk Mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 02-14-2008, 12:10 AM Thread Starter
Trunk Mod
Has any one eliminated the black trunk box and moddified a piece of metal to put in it's place and poss add another brake light.
KENNETH FORTUNE is offline
post #2 of 10 (permalink) Old 02-14-2008, 01:17 AM
You mean like this?
http://tinyurl.com/2qvj58
post #3 of 10 (permalink) Old 02-14-2008, 01:01 PM Thread Starter
I understand the top bolts but whats the bottom bolt for. And or what is it attached to.
Looks good. That's exactly what I was thinking about.
post #4 of 10 (permalink) Old 02-14-2008, 02:12 PM
Originally Posted by KENNETH FORTUNE View Post
.... but whats the bottom bolt for. And or what is it attached to
Check out KM's other pic HERE and you can see it holds the extra tall backrest support bars.
post #5 of 10 (permalink) Old 02-14-2008, 05:38 PM
What he said.
The material I used by the way is not metal , it is plastic. They sell it as an "emergency mirror" to cut and replace the side mirror on your car or truck if it gets broken. Sold in 5X7 inch sheets at automotive stores, and even Wal-Mart.
post #6 of 10 (permalink) Old 02-14-2008, 06:13 PM Thread Starter
Thanks I think I'm going to start playing around with the idea and try to make one.
I'm going to try that plastic stuff. It sounds like it would me easier to shape.
post #7 of 10 (permalink) Old 02-21-2008, 02:30 PM Thread Starter
Here's what I got so far.
First I used the plastic miror and cut it to size. Once I did that I decided I wanted to add a third brake light. So I took a piece of 1/4 thick alumnium sheet and cut it using the plastic outline. Trimed it down and polished it a little. Once I finish polishing it I'm going to add this led light.
I hope that it looks good. Once I'm done I will repost a pic.
Here's the link to the video of this light. It should get someone attention behind me.http://www.customdynamics.com/videos...derz_video.htm
post #8 of 10 (permalink) Old 02-21-2008, 04:30 PM
dirtrack650's Avatar
Looks great, but check local laws. I installed a flashing strobe brake light on my GL500 and was told in the state of Wa. it's not legal.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #9 of 10 (permalink) Old 02-21-2008, 05:43 PM
DT
Yes, certainly check the legality of that first.
A brake light modulator is one thing, but flashing LED's are another.
If it just flashed a few times then stayed on solid it might be OK, but with it going back and forth has me thinking it's for show or off-road use only.
post #10 of 10 (permalink) Old 02-21-2008, 10:31 PM Thread Starter
I did not think of that. I will check in to that thanks
