F&S Engine guard, no room for my feets! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-27-2014, 05:41 PM Thread Starter
AngryBob's Avatar
Got the engine guard mounted, took it for a short ride, and it was just not working out for me. I only have size 11 combat boots on, but I can only get like 2 inches of my toe on top of the shifter and that's only if I'm careful/precise about moving it under. Any more on the shifter, and after I downshift once, it will not travel up high enough to downshift again. Total safety hazard in my book, so I took it off.
Rear brake pedal side is a bit more roomy due to the pedal not being closer to the frame like the shifter, but still awkward.
Anyone else had similiar problems, and found a way to get around it?
Also I mounted highway pegs on the bar, and frankly they were painfully uncomfortable to use - way too high, made for an extremely uncomfortable seating position. I'm thinking if I go with a highway peg solution of some sort, it would have to be lower and further out laterally.
"wanting people to listen, you can't just tap them on the shoulder anymore - you have to hit them with a sledgehammer. and then you'll notice you have their strict attention"
AngryBob is offline
post #2 of 5 (permalink) Old 07-27-2014, 05:52 PM
put forward controls on it. it made a world of difference for me. im 6' and size 13 shoes
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #3 of 5 (permalink) Old 07-28-2014, 01:55 AM
I had to rotate the shifter lever up a couple of degrees.. after that it worked fine, and even better with my added highway pegs.
post #4 of 5 (permalink) Old 07-28-2014, 11:27 AM
Wolfie makes some awesome ones
post #5 of 5 (permalink) Old 07-28-2014, 04:42 PM
I had the F&S engine guard on my bike and removed it after a while.
I had no problem with the pegs I mounted, but the left foot was cramped on the shifter side. I also rotated the shifter lever up a notch like Slim said and it helped.
IMO the shifter on the VN750 does not stick out enough. I wish the peg end was about an inch or two longer.
