windshield material - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-30-2014, 08:35 PM Thread Starter
nopickles98's Avatar
windshield material
Found a very reasonable windshield on ebay that I think I would like. Was looking for something unobtrusive like a spitfire and found one that's a bit taller but made out of "high quality ABS".
http://www.ebay.com/itm/171360628284...S:1123&vxp=mtr
Guessing ABS would be fine for a windshield but must admit I don't know much about it. Any opinions?
I don't wanna pickle......
I just wanna ride my motorsickle.
Arlo Guthrie
http://www.youtube.com/watch?v=g266Uwp6ZnI
'98 VN750
purchased Nov 2012 w/ <8,000mi
previous plate (last time on the road legally) 2002 therefore.......
carb rebuild
AGM & Iridiums
R/R relocation
Kury voltmeter
Splines lubed & in excellent shape
Aug 2013 - new Shinko 230 TM oversized front & rear
Finally got'er shaved
nopickles98 is offline
post #2 of 7 (permalink) Old 07-01-2014, 03:11 PM
Okiebezer's Avatar
http://en.wikipedia.org/wiki/Acrylon...adiene_styrene
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #3 of 7 (permalink) Old 07-01-2014, 04:24 PM
Wasn't aware there was a clear ABS.
Most windscreens are acrylic or Lexan. Lexan is the toughest but needs an anti scratch coating. Acrylic is used in aviation alot.
But sorry, no personal experiance with windscreens made from ABS.
post #4 of 7 (permalink) Old 07-01-2014, 05:21 PM
Are there not four attachment points? I made my lowers out of Optix Acrylic from Lowes. Seems very strong (1/4 inch I think) and very clear. Says it doesn't yellow.
post #5 of 7 (permalink) Old 07-24-2014, 05:51 AM
Bump. I curious about the durability of that windshield made of ABS.
dyllansant is offline
post #6 of 7 (permalink) Old 07-24-2014, 02:59 PM
ABS is a tough flexible plastic. The Pontiac Fiero has its entire body made from it. Legos are ABS....
As I mentioned, first time I have heard of a clear ABS as it is usually opaque.
I'm not sure how scratch resistant it is... Or if they coat it. (Polycarbonate screens AKA Lexan, are usually given an a scratch resistant coating)
I suggest you get one and let us know how it does...
post #7 of 7 (permalink) Old 07-27-2014, 05:03 AM Thread Starter
I ended up getting it. I think it looks good. Can get a pic up in a day or two if interested. Like I said, a bit taller so a bit less helmet turbulence. A bit of distortion looking thru it, but that's really not what it's for. As far as durability and scratch resistance - only miles will tell . I'll keep it for a while.
And for the $, I doubt it's been coated w/anything.
ID:	17658   Click image for larger version
ID:	17666   Click image for larger version
Arlo Guthrie
'98 VN750
carb rebuild
AGM & Iridiums
R/R relocation
Kury voltmeter
