Toolbox door keeps opening - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-15-2014, 11:39 AM Thread Starter
Is there a quick fix for this? It seems like either the plastic catch is worn or is somehow misaligned. Is this a common problem?
-Robert
RobertGary1 is offline
post #2 of 11 (permalink) Old 06-15-2014, 01:22 PM
-Robert
...not that I am aware of.....is the metal Lock Tab of proper length ?
post #3 of 11 (permalink) Old 06-15-2014, 02:07 PM Thread Starter
Should be unless it recently shrunk. This just started the other day.
-Robert
post #4 of 11 (permalink) Old 06-15-2014, 02:35 PM
Photos would help here.
Stock box lock was reasonably solid, but as the box is plastic it could be pried open. Sounds like something is off on yours.
post #5 of 11 (permalink) Old 06-15-2014, 08:04 PM
is the hinge starting to fail....and by hinge, I mean the thin plastic that bends when you open it. It might be that the bottom seam is starting to separate.
Heavy duty packing tape will fix it.
post #6 of 11 (permalink) Old 06-16-2014, 12:31 AM
Duct tape is your friend
EDIT: Suggestion....Occasionally riders lose the entire Lock on the road..... to prevent, place RTV or Silicone on the threads of the Lock Latch.
post #7 of 11 (permalink) Old 06-16-2014, 08:38 PM
My lock fell out while i was riding lol
Little00gt is offline
post #8 of 11 (permalink) Old 06-17-2014, 01:38 AM Thread Starter
I think I figured it out. The bolts for the seat were loose causing the plastic box to ride up and not catch the latch. Tightening the bolts seems to have fixed it. I usually just hand tighten them so I'll have easy access to the battery. Need to find wings nuts or similar I guess.
post #9 of 11 (permalink) Old 06-17-2014, 07:51 AM
That seems strange to me. I thought the door and back panel were bolted to the box making it one solid unit....so if the box "rode up" the door would too.....
But yes, do use a goop of silicone on the lock threads...many have lost the entire lock.
post #10 of 11 (permalink) Old 06-17-2014, 09:39 AM
Memphis's Avatar
Hell mine doesn't have a door or a lock, I didn't even realize it was supposed to!
Memphis is offline
