Tool Box Lock - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-11-2014, 09:55 PM Thread Starter
spock750's Avatar
Tool Box Lock
I know, I didn't check the lock to see if it was loose. Well it was and I lost the lock. Does anybody have the length of the barrel of the lock? I bought one to replace it but the barrel was too long and goes to far into the toolbox and the lock won't line up with the catch inside the box. I will silicone the nut on this time. Thanks Guys. Oh and I did search in the verses and couldn't find the length. Might have missed it tho.
2002 Vulcan 750
things to do: When time allows.
Relocate rear turn signals. (have parts) Done. Thanks Pittdave
acct to mcct (TOC) Done
Iridium plugs
Luggage rack
Hiway bars and pegs
Tank Bib Done (Thanks Romeobravo172)
spock750 is offline
post #2 of 4 (permalink) Old 04-13-2014, 08:22 PM
razorbackvn's Avatar
Lock
Standard cam lock will work. I bought one at our local hardware store had three different tabs all were to long . I took the flat one to work and ground about a half inch off it worked perfect.
razorbackvn is offline
post #3 of 4 (permalink) Old 04-13-2014, 10:23 PM
idk.....suggest 1/4" shaft length....
good luck
post #4 of 4 (permalink) Old 04-14-2014, 09:35 AM
if you need one, I have a working lock (complete with trunk, broken hinge) I can part with.
you will need to get a keymade/rekeyed
michiganteddybear is offline
