My Plexistar 2 Cracked, Looking for an Alternative. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-18-2014, 12:23 PM Thread Starter
Roach's Avatar
I bought a National Plexistar 2 last spring and it cracked when I flexed it to take it off the bike in October.
I only had it 6 months and National won't do warranty for their Acrylic models, only polycarbonate.
So now I'm looking for a windshield that offers a similar amount of protection, and is also covered by some sort of warranty.
Any suggestions?
I might attempt some sort of repair for the time being, but ultimately I think it will be replaced.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #2 of 12 (permalink) Old 03-18-2014, 12:55 PM
I'm very happy with my Street Shield EX. Looks good too.
post #3 of 12 (permalink) Old 03-18-2014, 02:06 PM
I know how to stop the crack and reinforce it, if you're interested.
post #4 of 12 (permalink) Old 03-18-2014, 06:19 PM Thread Starter
Roach's Avatar
That would be handy info.
Are you talking about stop drilling the end of the crack?
Street
Dirt
Roach is offline
post #5 of 12 (permalink) Old 03-18-2014, 06:36 PM Thread Starter
Roach's Avatar
That's a no go. It's an acrylic model so no warranty on that one.
Street
Dirt
Roach is offline
post #6 of 12 (permalink) Old 03-18-2014, 07:26 PM
I had a similar thing happen to my Memphis Shades Malibu. (All done from the back) I drilled the end of the crack (not quite all the way thru) then Heated the drill point with a torch to "seal" the drill point. Then shaved some of the length of the crack with an angle grinder. I then coated the back side with fiberglass resin (neatly).
Sanded it smooth & painted. The front of mine was painted though. So, it wasn't noticeable. I had met with folks while it was like that & nobody really noticed.
It's a cheap fix till you find something you like.
post #7 of 12 (permalink) Old 03-18-2014, 09:28 PM
That's it ... drill a small hole through the top of the crack, then I figured to stitch a piece of stainless wire in paired smaller holes at the bottom and almost the top. Frankenshield
The rough up with resin may be less noticeable and wouldn't take a lot of resin.
Paint on the inside of the shield will have a nice gloss on the front, if you want to hide it more.
I've patched atv bodies with hot melt glue, but it always looks like open heart surgery scars on the side with the glue.
post #8 of 12 (permalink) Old 03-19-2014, 11:16 AM Thread Starter
Roach's Avatar
Thanks guys,
I read Weld-On 4 works well for cracks on another forum. Just need a needle applicator.
Edit: Something like this would be perfect but it doesn't ship to Canada.
Street
Dirt
Roach is offline
post #9 of 12 (permalink) Old 03-19-2014, 12:33 PM
try a plastic syringe:
LIKE THIS
Search ebay as well...some hobby shops carry similar for pretty cheap.
EDIT: many dentists have them....maybe you can buy one off of them.
post #10 of 12 (permalink) Old 03-19-2014, 05:13 PM Thread Starter
Roach's Avatar
I just went to a local plastics place here in town and they sold be a little needle applicator bottle and some Weld-On #3 for $15.
I'll give this repair a go tonight.
They also said they wouldn't bother stop drilling when using this stuff.
Street
Dirt
Roach is offline
