guages - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 07-15-2007, 08:38 AM Thread Starter
guages
I want to change to a sleeker style guage. Will any guage be able to be used or do we need specific ones to be accurate?
tanz1983 is offline
post #2 of 13 (permalink) Old 07-16-2007, 04:27 AM
Drive less, ride more...
theauhawk's Avatar
What make/model gauge(s) are you most interested in?
If you're a little more specific about what you want, I think you might get some more detailed feedback...
'05 VN750
theauhawk is offline
post #3 of 13 (permalink) Old 07-16-2007, 01:34 PM
I've been thinking about changing my tank out so I can have the single gauge in the center of the tank and give the front of my bike a cleaner look. That and the extra fuel capacity would be nice too. Anyone on here done something like that?
shameless is offline
post #4 of 13 (permalink) Old 07-16-2007, 04:10 PM
I think it was on eBay, I saw a smaller tach that is supposed to be for the Vulcan 750.
As for the tach, as I understand it, it works off one of the coils, so any that work like that, I'd think, would work on the Vulcan.
The speedo may be a bit more difficult. You'd probably need to have the correct gear ratio for it to be accurate. But that's not to say there isn't something out there that'll work. Just may take some trial & error to find a good replacement.
post #5 of 13 (permalink) Old 07-16-2007, 06:48 PM Thread Starter
I wanted to go with the harley sportster speedo and gett rid of the tach.
tanz1983 is offline
post #6 of 13 (permalink) Old 07-19-2007, 08:17 PM
whats to stop you putting the new guage in the OEM tank?
you got to be careful when putting a new tank on, that its not to bulky, because believe me, its looks awful.
I was planning on putting the speedo in my tank but i was just too damm lazy, so i opted just to fit a flush fit pop-up cap instead.
One thing, if you do the speedo on tank thing, the tank is made of REALLY thin steel not heavy guage stuff that aftermarket parts are, and its easy to blow holes in with the welder !!
Bucky is offline
post #7 of 13 (permalink) Old 07-20-2007, 03:51 AM
And hold LESS fuel ??!!
It would look different though.
And if the Sportster has a 19" front wheel, the speedo would probably work, as long as it's not electronic.
Not sure about the tank though. I've never looked at one to know if they are anywhere close to similar in design/fit. But if you're handy with a tig welder, anything will fit!
post #8 of 13 (permalink) Old 07-20-2007, 06:53 AM Thread Starter
I don't want anything for the tank. I just want smaller guages. So if I understand ypu right, another motorcycle with a front whell of 19", the speedo will work?
tanz1983 is offline
post #9 of 13 (permalink) Old 07-20-2007, 08:06 AM
So if I understand you right, another motorcycle with a front wheel of 19", the speedo will work?
MOST speedo's use the same sized/shape cable end that goes into the speedo unit. (I even used a bicycle one on a dirbike before)
So, I would think, if the donor bike had a 19" wheel, it should be reasonably close to the same internal gearing to be somewhat accurate, and the OEM cable on the Vulcan should fit.
But, as with any mis-matching of bike parts, it's usually trial & error.
If you can find parts cheap, give it a try.
post #10 of 13 (permalink) Old 07-23-2007, 09:57 AM
Actually I think a tank can be pulled off of a VN800 and used. Close in size and is already designed to have the speedo built into it...
