help with handlebars and grips - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 02-19-2014, 10:46 AM Thread Starter
"All the way AIRBORNE"
ace200402's Avatar
just looking to replace the handle bars with some 13 or 14in ape hangers but not to hang, im using them to relax back on the bike, also i want to replace the grips but i noticed the throttler is built in and i cant find a set for them any idea ??
ace200402 is offline
post #2 of 9 (permalink) Old 02-19-2014, 10:53 AM
Dr. Vulcanstein
jadabull's Avatar
EBay has a lot of bars and grips, just have to make sure they are 7/8" and NOT 1" unless you modify them. The grips slide over the throttle tube, its not one piece. 12" apes, no modifications needed, 14" slight mods, anything over that plan on getting longer cables. Happy hunting.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 9 (permalink) Old 02-19-2014, 11:42 AM
If you still have the stock grips you'll have to cut the throttle side off as its formed around plastic ridges on the tube itself. (A razor blade slice down the grip will do it, don't go too deep as the throttle tube is plastic)
You'll need to file or grind off those plastic tabs to get a new grip on. Grips sold in pairs for 7/8 bars will have one that has a larger inside diameter to fit over the throttle tube...make sure you have the proper grip for that side before trying to mount it.
post #4 of 9 (permalink) Old 02-19-2014, 11:43 AM Thread Starter
ace200402's Avatar
so the throttle grip can be slid off and replace the same as a cbr929 just need elbow grease lol
thanks knife, that was the same as the 929 , lil issues at first but got it off then so now i cant wait to order some
post #5 of 9 (permalink) Old 02-19-2014, 07:12 PM
Our stocks are consudered "mini apes"...theyre 7 1/2" rise...if you go too high, you'll need new, longer cables and such....I just ordered a pair of 11" WIDE apes (Im a lanky 6'1")....the width is what ya really want for comfort (helps control the bike better too)...
http://www.phatperformanceparts.com/.../hh-55-240.htm
Best prices Ive seen here at Phat.....
These are REALLY sweet, but cost a bit more....
http://www.phatperformanceparts.com/.../0601-1073.htm
Dont worry about the lil dimple for the thottle....2 wraps of electric tape wiped in gas will keep em on....
post #6 of 9 (permalink) Old 03-11-2014, 11:10 AM
Big Nick's Avatar
Yep just fitted a set of 12 inch Ape Hangers,and they just, fitted, with all of the stock cable and harness.
$30 second hand.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #7 of 9 (permalink) Old 03-11-2014, 02:28 PM
Several have used a set of goldwing kuyr grips, including myself.
post #8 of 9 (permalink) Old 03-11-2014, 05:48 PM
Big Nick's Avatar
To Ace, I've found Grab On Grips to be a good bonus for thickness and vibration reduction, for the comfort of the hands, they look like fat foam rubber. Very comfortable.
It may only be my observation, but taller bars within reason tend to throw a bit more weight on the back end, don't ask me why but that's the feeling,add better vision being upright, they also tend to fire you into the air, when u hit a car as opposed to centre punching it with your head. Powering out of corners and the back end feels more glued to the road as well. Just my thoughts and seat of the pants feeling.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #9 of 9 (permalink) Old 03-11-2014, 10:32 PM
I refuse to buy anything Kury, unless its used and half price....gotta be the most overpriced company there is.....I go to V-Twin Mfg first....their 7/8 is limited though....
But Drag Specialties make nice "mid-apes" for under $100....I went with the others because they were like $58....shipped from Europe though, so no "expedited shipping", lol....
For the Vulcan....and this is coming from 40 yrs of biking, go WIDE mid apes....the width gives you so much more control.....
