14" apes on 04 vn750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 01-13-2014, 01:24 PM Thread Starter
I am putting apes on an all black 04 vulcan 750 and can't seem to find new cables to replace the shorter old cables with. Anyone know where I could find said cables and at a decent price? Also, where can I find 1" switches will fit my bike. It seems that everywhere I have asked they say I need costume switches.
Thank you
dwjohnson is offline
post #2 of 25 (permalink) Old 01-13-2014, 01:45 PM
Six second search:
https://www.vn750.com/forum/showthread.php?t=44434
Why do you want 1" switches for a 7/8" bar?
post #3 of 25 (permalink) Old 01-13-2014, 02:05 PM
Dr. Vulcanstein
jadabull's Avatar
Contact motion pro for the cables, bars are 7/8" so you'll need to use something to shim the 1" switches......sometimes people are looking for answers not criticism
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #4 of 25 (permalink) Old 01-13-2014, 02:20 PM Thread Starter
Thanks. I have searched motion pro and have found cables just don't know which are compatable for my bike. It's my 1st bike if that helps u understand why I'm a bit ignorant, so this is a learning experience for me. Also Ive kind of "customized" my risers, brake reservoir mount, and clutch mount to fit NYC copper 1" bar (regarding the switches). Couldn't really find 7/8 bar with the style I was looking for
post #5 of 25 (permalink) Old 01-13-2014, 05:09 PM
Dr. Vulcanstein
jadabull's Avatar
Stock bars have an 8" rise, and I believe you can go up to 14" (may have to splice/add length to the kill switch & starter wires)without having to order new cables an such. Just add the extra length you have an call motion pro and tell them you need them FOR EXAMPLE 6" over the stock length and they already have the Vn750's stock length on their data base. I have worked with them in the past, good company! If you didn't have your custom risers on stocks should still work, so whatever extra length your risers add, way 2" tell them you need 2" over stock, or maybe 3.5 for a little added wiggle room.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 25 (permalink) Old 01-13-2014, 05:19 PM Thread Starter
Great information! THANKS to the both of you. I don't care really about smart comments as long as it's followed with useful info. I'll post a pic when it's done.
post #7 of 25 (permalink) Old 01-13-2014, 09:23 PM
Stock are actually 7.5"...I just ordered a pair of Highway Hawk 12" mid-apes for mine....mine are so tight NOW, that even with 4.5" rise, call for longer....mostly the clutch and front brake and speedo....thottle can be rerouted....
Check here for budget bars....will take awile. as they come from Europe....
http://www.phatperformanceparts.com/.../hh-55-240.htm
Drag Specialties has a similar at a higher cost...
post #8 of 25 (permalink) Old 01-13-2014, 10:50 PM
geezyrider's Avatar
Originally Posted by jadabull View Post
Stock bars have an 8" rise, and I believe you can go up to 14" without having to order new cables an such. Just add the extra length you have an call motion pro and tell them you need them FOR EXAMPLE 6" over the stock length and they already have the Vn750's stock length on their data base. I have worked with them in the past, good company! If you didn't have your custom risers on stocks should still work, so whatever extra length your risers add, way 2" tell them you need 2" over stock, or maybe 3.5 for a little added wiggle room.
Could the existing bars be raised with some kind of extender/riser bars? Also it doesn't lookto me that the master cylinder fluid line could be raised more than a few inches without adding a new line or extending the existing one.
geezyrider is offline
post #9 of 25 (permalink) Old 01-13-2014, 11:00 PM
I think raised risers are made for the7/8" bars.yes you can get longer front brake lines.need one for my gs but I had one lying around
post #10 of 25 (permalink) Old 01-13-2014, 11:06 PM
Dr. Vulcanstein
jadabull's Avatar
Yes, you can get 7/8" risers for stock bars. I also plan on getting 14" bars in the future. Slim has 14" apes on his scoot and used the stock equipment.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
