Hard Saddlebag bracket size - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-23-2013, 10:57 PM Thread Starter
Smile Hard Saddlebag bracket size
Does anyone know the size of the bracket needed to install MUTAZU GA Hard Saddlebags? I order some brackets (I haven't order the saddlebags yet) and want to make sure I have the correct bracket. The bracket I got has the measurement of 6"x4"x6" and it's shaped like a U with a slight angle on one of the bars sort of l_/
Please let me know the size of the bar going down ____, the bar going across the bottom ____ and the size of the bar going up on an angle _____.
I did also buy from gxetreme the relocation rear light bracket to use with the saddlebags.
Thank you everyone for your help....
hacez529 is offline
post #2 of 6 (permalink) Old 11-24-2013, 01:01 AM
I do not know the answer you are seeking....but I would think if you measure the relocation brackets mountigs would provide your answer.
Maybe others are able to chime in with a more exact answer.
post #3 of 6 (permalink) Old 11-24-2013, 03:57 AM
The brackets you have will work, They are a little smaller than the KF&S brackets, but the same meathod will work for you as this one HERE
post #4 of 6 (permalink) Old 11-24-2013, 10:46 AM Thread Starter
Smile
Great glad hear that. Thank you for you help with the question.
hacez529 is offline
post #5 of 6 (permalink) Old 11-24-2013, 11:24 PM
Okiebezer's Avatar
I've had a set of his relocator brackets on my bike for well over a year with no issues. I'd buy them again.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #6 of 6 (permalink) Old 11-24-2013, 11:44 PM Thread Starter
What are the measurements of your U shape brackets that attach to the GA hard saddlebags and then to the relocating brackets?
Please...
hacez529 is offline
