Can I ask a dumb question about turn signals? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-18-2013, 12:42 PM Thread Starter
son-of-fire's Avatar
Hey all. I see aftermarket turn signals all over the place on ebay, but it seems like I can't find any that I think would work with my 93 750? They all have a screw mount, but the ones on my bike turn in and out of the plastics. I don't even know if that makes sense, although I'm sure you guys know what I'm talking about.
So do I just buy whatever? Use washers and just screw it on tight? Just not sure what to do at this point.
1993 Vulcan 750 "Sookie"
1980 KZ750 LTD (Project) "Saki"
2007 Honda Rebel (Sold) "Lucky"
son-of-fire is offline
post #2 of 11 (permalink) Old 10-18-2013, 12:48 PM
Not sure if you are looking for front or rear ones....you can buy ones that are like OEM and mount as they should normally HERE for front signals
Or if you want to change the look, go with aftermarket ones and make the mounts work with washers and whatever you need to do to mount them.
post #3 of 11 (permalink) Old 10-18-2013, 01:18 PM
I'll add if you don't get the OEM replacement in the link, and buy all new LED signals, you'll need a new flasher unit as the one on the bike won't work will LED signals....
post #4 of 11 (permalink) Old 10-18-2013, 06:22 PM
Dr. Vulcanstein
jadabull's Avatar
The leds I got for the rear worked fine, didn't need to buy a flasher unit. I drilled 1 hole on each side of the taillight bezel to mount.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 11 (permalink) Old 10-18-2013, 06:43 PM
One can use large fender washers to mount the aftermarkets into the existing holes....awhile back, I had Yamaha sigs on mine, and they had the threadded shaft (and solid stem)...with that type, you can eliminate the extra ground wire too, which the rubber Kawis require, since they ground thru the frame (like normal bikes)...
post #6 of 11 (permalink) Old 10-18-2013, 09:35 PM
If you need signals I got a bunch of them for sale.
post #7 of 11 (permalink) Old 10-19-2013, 07:48 AM
That's because you didn't replace "all" of them, just the rear. As long as there's one standard bulb on the circuit you don't need a diffrent flasher. RIF.
post #8 of 11 (permalink) Old 10-19-2013, 03:26 PM
Smile Led's
LED'S are the way to go. Uses way less electricity. That much more power to crank engine over.
qxinfinity is offline
post #9 of 11 (permalink) Old 10-19-2013, 04:34 PM
The only lights that come on before you crank the engine are the instrument panel lights. The headlight, and parking lights don't come on until the bike starts. I see 100 reasons why to switch over to LEDs but because they take away from starting power isn't one of em.
post #10 of 11 (permalink) Old 10-19-2013, 11:45 PM
Dr. Vulcanstein
jadabull's Avatar
Thanks KM, never even realised that.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
