Ma Kaw's F&S engine guard prevents upshifts on my motor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 09-22-2013, 12:22 AM Thread Starter
Unhappy Ma Kaw's F&S engine guard prevents upshifts on my motor
When I got back to riding last season after missing 4 riding seasons due to an accident, I had to rotate the shift lever up one spline. This was necessary because my ankle is not as flexible as it used to be, and also I now have a 3/4" lift in the sole of my left shoe. Therefore I could not get my toe under the shift lever "pedal" to upshift until I rotated it up one spline.
I finally got the engine guard and highway pegs mounted on the bike, then discovered on the test ride that I could not shift into second gear due to clearance issues with the engine guard. I am curious to know if anyone else has had a similar problem, and what you did to get around it.
I think an extra 1/4" vertical movement is all I need to be able to reliably upshift. I was talking to a Nomad rider yesterday at bikenight who has an acetylene welding torch. Our thoughts are to clamp the shift lever in a vise, heat it red hot down at the bend then pull the lever out a few degrees to open the bend a few degrees. I know this will probably discolor the stainless steel lever and maybe take some strength out of it too. So is this a smart thing to do, or should I find a different method to get the shift clearance I need?
post #2 of 20 (permalink) Old 09-22-2013, 03:24 AM
the lever can be bent cold a few degrees, I bent my spare one to almost 90 before it broke (I was trying to break it).
post #3 of 20 (permalink) Old 09-22-2013, 09:20 AM
....what I did on my older FWD controls setups was to cut a "V" out of the top, bend it, then reweld.....once ground and polished, you can barely tell.
post #4 of 20 (permalink) Old 09-22-2013, 10:57 AM
R/R = Relocated Redneck
Jakzen's Avatar
Had the same problem with mine, couldn't shift into 2+. I just took the lever off and rotated it down a couple notches on the shaft. worked like a champ.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #5 of 20 (permalink) Old 09-22-2013, 11:42 AM
You can bend the lever a few degrees without needing to heat it up. It's not stainless steel btw, just chrome plated mild steel.
Am guessing you are talking about getting a position "between". the ones provided by the splines.
post #6 of 20 (permalink) Old 09-22-2013, 12:43 PM
bamafrankie
bamafrankie's Avatar
I think he is talking about bending it sideways so the shifter goes up along side the crash bar. Hoss you could use a press if you know anybody that has one
Sent from my Droid
bamafrankie is offline
post #7 of 20 (permalink) Old 09-22-2013, 01:07 PM
Jakzen's Avatar
I went back and read the OP and I think you're right bama. I think there's three options. Bend it out past the guard, fabricate a heel/toe shift lever or make a bracket that drops the peg and rotate the shifter down.
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
post #8 of 20 (permalink) Old 09-22-2013, 06:15 PM
How about moving the crash guard up a bit by elongating the holesin the mounting tabs
post #9 of 20 (permalink) Old 09-22-2013, 06:51 PM
I always thought the guard was poorly designed.... Hoss is not the first person to have problems with the shifter with the thing installed.
I though his problem was about the up/down position, not the side to side one.
Guess he can clear that up...
post #10 of 20 (permalink) Old 09-22-2013, 08:31 PM
bamafrankie
I have the same prob with mine i wear steel toed boots for work had to move shifter up a spline or two so i could fit the boots under the shifter, wouldnt work i had to move it back just dont ride my bike to work. Looking for forward controls or going to build some to solve problem,( or removed engine guard)
Sent from my Droid
